*HELP* - Funny noises coming from engine
Old 07-13-2001, 05:42 AM
on bin laden
fbazakos's Avatar
Well I know it's late ... but I got a little worried about my CLS tonight. I was the designated driver, so no comments about that. Before we went into the bar, we were sitting in the lot, I turned my AC on (I usually dont run it), and I noticed the engine working hard, but I didnt think anything of it ... just figured it was normal when the clutch engages for the AC compressor. So, now at 1 am, bar closes, and all my buddies want to see the 2 new neuspeed bars i put in today. so i turn my car on, they start blasting some greek techno, and i pop the hood. as they check it out, i noticed a loud ticking sound (sounds like it is coming from below the engine cover). i remembered the sound from earlier, and that my AC was still on. when i shut the AC off it stops. I figure next time I bring the car in, they'll look at it for me. Well now as I'm driving home (AC off) i notice a deep deep sound coming from the engine if i pushed the revs past 2000 rpm. It was very scary becuase the sound was remenicent of when i blew my engine in the lincoln. so i drove home slow, parked it outside, and I'm gonna check it out in the morning. I possibly may call Acura TLC and have them tow it in to check it out. Note: I got no check engine lights, or anything. Any ideas guys??? and gals???
Old 07-13-2001, 09:28 AM
Old timer
JRock's Avatar
Well my car is still making the noise I heard before I got a binded pulley replaced, so I just said Fuck it, I'ma run it till something breaks. There's obviously no other way to figure out what's wrong with it. Or maybe it's just normal to have a loud intermittent ticking coming from the engine bay when it's idling in a drive gear.
-J
Old 07-13-2001, 09:34 AM
mr tl's Avatar
Originally posted by fbazakos:
<STRONG>they start blasting some greek techno </STRONG>
haha. whats that???
i honestly think its normal and just your imagination. how often do you use the ac? i rarely use mine, but whenever i do i get scared because the car seems to shake too much
wouldnt hurt to take it in
Old 07-13-2001, 10:21 AM
sundance_gold's Avatar
I have this annoying vibration, like a heat sheild or something is loose, when the car is in gear and the AC is on. I mainly hear it when I'm pulling into or out of a parking space (because the radio's off!).
Old 07-14-2001, 03:29 AM
jdl75's Avatar
I didn't notice a mileage indication, but are you sure it wasn't your valve train? If your oil filter is gummed up, or if you are using a crapy filter (Fram has a few notorious for inducing valve problems), you may not be getting sufficient oil flow to the valves.
[ 07-14-2001: Message edited by: jdl75 ]
Old 07-14-2001, 05:04 PM
on bin laden
fbazakos's Avatar
18,000 miles.
my buddy who is into hot rods think it sounds like the lifters ... haha
oh, i use honda filters. now dont tell me honda makes bad filters, i go thru hell to get those
Old 07-14-2001, 05:59 PM
www.drippinwet.com
acura_service's Avatar
i'll ask the techs monday if you like
Old 07-14-2001, 08:25 PM
on bin laden
fbazakos's Avatar
Originally posted by acura_service:
<STRONG>i'll ask the techs monday if you like</STRONG>
yes please, and let me know, thanks!!!
Old 07-14-2001, 09:58 PM
rwwlaw's Avatar
This shit really scares me! Engine probs, Tranny probs and overall poor quality! What are we talking about here a fucking Yugo
Old 05-10-2017, 01:42 PM
5th Gear
Anthonydonanto50 donato's Avatar
I'm having the same issue, My 2008 acura tl 3.2 engine is making a loud noise like if metal plate are hitting or something. When I am at a complete stop the car shakes then the sound begins and I have to give it some gas or else it will stall. Is anyone else having the same issue
Old 05-10-2017, 01:44 PM
Received 16,260 Likes on 11,971 Posts
have you had the car since new? when did you buy this car? when did the noise start happening? sounds like a few issues, motor mounts and maybe a vacuum leak
Old 05-10-2017, 02:30 PM
5th Gear
I had it for three years, I changed two of the three mounts I also changed the spark plugs
Old 05-10-2017, 03:18 PM
Received 8,584 Likes on 6,630 Posts
which two?
might be a loose catalytic converter heat shield
Old 05-10-2017, 03:46 PM
5th Gear
the front and rear
Old 05-10-2017, 03:49 PM
Did you replace with mounts that had the vacuum assist lines?
Check your cat heat shields
Old 05-10-2017, 03:51 PM
5th Gear
acura loud clucking noise
Help me please My car is making this loud noise but only when I am in drive or reverse, I have taken it to two different mechanic and they have never heard this noise. I can also be driving and then the car just shuts off and the entire power goes out,
It vibrates will hard then the noise begins, I have changed the front and side motor mounts already
Old 05-10-2017, 03:52 PM
5th Gear
yes I notice the front one had a vacuum hose
Old 05-10-2017, 03:53 PM
If power goes out while driving, you have an issue with your alternator going out, maybe loose tension on the drive belt, battery, or battery terminals.
wait..
the front and rear
which is it?
Old 05-12-2017, 08:08 AM
teh CL's Avatar
Check your grounds as well
Old 05-16-2017, 04:31 PM
RedlineCL-S's Avatar
Did you check the tensioner? I had the same ticking sound and saw that my tensioner was going crazy rocking back and forth.
02-25-2020 09:57 AM
2012wagon
09-29-2015 04:21 PM
iCrap
09-11-2015 06:21 PM
Mike Bertram
09-10-2015 09:27 AM
Quick Reply: *HELP* - Funny noises coming from engine
