noisy after body work
Hi! Anyone know how to remove the back passenger side interior panel from an 01 CL/S?
Had body work done some time back, and it's been noisy ever since?
Thanks for any help
JoeC
Thanks for any help
JoeC
Removing the rear seat first might make it easier, or atleast the lower cushion. To remove cushion put your hands under it from the front and pop it up off the plastic clips.
For the panel there is 1 screw you need to remove I believe near the middle lower section of the panel. The rest is just held on with white plastic clips. Pull it off. Check the white clips and replace the damaged ones. Make sure all the seat bolts are in place also.
When I had work done the shop left the seat back section bolts out.
cycdaniel
12-17-2019 10:58 AM
DiamondJoeQuimby
09-10-2015 11:40 AM
