noisy after body work
Old Dec 18, 2014 | 05:04 PM
Joe.C's Avatar
Hi! Anyone know how to remove the back passenger side interior panel from an 01 CL/S?
Had body work done some time back, and it's been noisy ever since?
Thanks for any help
JoeC
Old Dec 20, 2014 | 12:10 PM
brian6speed's Avatar
Lone Wolf
Removing the rear seat first might make it easier, or atleast the lower cushion. To remove cushion put your hands under it from the front and pop it up off the plastic clips.
For the panel there is 1 screw you need to remove I believe near the middle lower section of the panel. The rest is just held on with white plastic clips. Pull it off. Check the white clips and replace the damaged ones. Make sure all the seat bolts are in place also.
When I had work done the shop left the seat back section bolts out.
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
acurajj
Sep 19, 2015 03:47 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
