Excelerate Performance: XLR8 Clutch Systems Now Available!!!
Old Apr 21, 2015 | 01:22 PM
ExcelerateRep's Avatar
Former Sponsor
Excelerate Performance is excited to release our XLR8 Clutch Systems!! Our systems only work with the manual transmission Acura CL.
To view the options, simply follow the link below and enter your vehicle information.
XLR8 Clutch System - Excelerate Performance - Japanese and European Performance Specialists!!
The systems are available in the following versions:
Daily
This clutch kit was engineered for those with bolt on modifications.This kit includes a heavy duty pressure plate, which has an increased clamp load with little or no increase in pedal pressure. The organic disc material has a high metal content that increases the co-efficient of friction by two times over a stock lining and increases rotational strength up to a 12,000 RPM burst point. Overall, this clutch system maintains a stock feel while offering strength and durability. The recommended usage is for a vehicle that is driven daily, for street performance or even a moderate race application. Torque capacity will be roughly 340 ft/lbs.
Street/Strip
This clutch kit was engineered for the street/strip climate. The pressure plate is precision balanced for vibration free operation at high RPMs.The friction material is a kevlar design. The recommended usage is for a vehicle that is driven daily, for street performance or even those used for rally or endurance racing. Torque capacity will be roughly 425 ft/lbs.
Drag
This clutch kit was engineered to handle heavily modified cars and designed to function according to the specific needs of the drag strip/track. Discs are a segmented puck design (6 puck setups available), which reduces rotational mass and are assembled with all high carbon component pieces for maximum strength. The friction material used is graphite-impregnated ceramic, which is perfectly suited for drag racing because of its maximum friction co-efficient, rapid heat dissipation, and abrupt engagement characteristics. The recommended usage is for a vehicle that is used for drag racing or drifting. Torque capacity will be roughly 500 ft/lbs.
Flywheel
The XLR8 flywheels are made by AASCO Motorsports. AASCO has been manufacturing flywheels for over 20 years. Their unique ability to manufacture thousands of the highest quality OEM replacement light-weight flywheels as well as several hundred custom variations differentiates them from the competition. AASCO maintains a high level of quality control.
Each kit includes a pressure plate, disc, flywheel and release bearing. Pilot bearing not included. Each kit and flywheel will be supported by the manufacturer’s warranty.
Old May 6, 2015 | 12:07 PM
Former Sponsor
We have these clutch systems in stock and ready to ship!!
Old Jun 4, 2015 | 02:59 PM
Former Sponsor
Feel free to visit our website or send me a PM for a quote!
Old Jun 4, 2015 | 03:29 PM
Karanx7's Avatar
Unregistered Member
I already bought and installed an AASCO flywheel. I believe they have replaceable friction surfaces.
When my OEM clutch goes out, can I just replace it with your clutch and a new friction surface? Or would I need to buy an entirely new flywheel to fit your clutch?
Old Jun 4, 2015 | 05:03 PM
Former Sponsor
You should be able to use the AASCO flywheel you have without any issues.
Old Jun 4, 2015 | 09:09 PM
fsttyms1's Avatar
I have the AASCO flywheel with this clutch and pressure plate.
Old May 26, 2016 | 03:08 PM
Former Sponsor
We now offer kits without the Flywheel, for those of you who just want to resurface and reuse your OEM unit!
Old May 27, 2016 | 09:10 AM
brian6speed's Avatar
Lone Wolf
Will be contacting you about this kit when my oem starts slipping. Shouldn't be long considering how I abuse it.
Which kit would you recommend for an autocross and road course car that still is driven on street? Don't plan on pushing over 300 whp or wtq. Maybe down road do NA build with 350 whp max.
Old May 27, 2016 | 03:14 PM
Just to clarify, you guys are now offering your Heavy Duty Pressure Plate and an XLR8 UNSPRUNG clutch disc, for the CL-S6, that can be used in conjunction with a new/resurfaced SPRUNG OEM DMF, should one want to go that route?
Old May 28, 2016 | 10:44 AM
Karanx7's Avatar
Unregistered Member
No, the clutch is sprung I think.
Old May 28, 2016 | 11:10 AM
lol, yes, i suspect that as well.
Not sure if it is prudent to use a sprung clutch disc with a sprung OEM DMF for the CL-S6, though. :
Old Jun 2, 2016 | 09:37 AM
Former Sponsor
Our Strip series is a sprung disc that can handle up to 425 ft/lbs of torque and would be great for a auto x or road car. The Daily kit would also be suitable but if you want something with a little more sporty pedal feel that can handle more abuse, the Strip is the way to go.
That is correct, our clutch discs are sprung, and should work with oem flywheels without any issues. we also sell just the pressure plates/clutch discs separately for those that want to run a different aftermarket flywheel.
Old Jun 2, 2016 | 12:44 PM
Lone Wolf
Think I'll go with daily since I'll never have over 340wtq.
Is there any discount code for free shipping?
Old Jun 2, 2016 | 07:21 PM
Karanx7's Avatar
Unregistered Member
It's fine to have the extra dampening. You can also run a single mass flywheel with an UNsprung clutch if you wanted (you would just have no "give").
Old Jun 3, 2016 | 01:11 PM
Former Sponsor
Pmed!
Old Jun 6, 2016 | 03:47 PM
Sean_CLS6's Avatar
It's good to see this thread because my stock clutch just started slipping when abused at 145k. Could I also have the free shipping code? Maybe we could get a group buy going?
I think I may go with the 2nd level kit for the sportier feel
Old Jun 8, 2016 | 09:54 AM
Former Sponsor
PMed! We could definitely put together a group buy. It would probably be along the lines of:
5 orders - 5% off and free shipping to the continental 48 U.S.
10+ orders - 10% off and free shipping to the continental 48 U.S.
Group buy would last two weeks, until Friday June 24th.
Old Jun 17, 2016 | 06:22 AM
Lone Wolf
My oem replacement clutch is slipping after under 5000 miles. This thing is junk. It cannot handle full throttle in 2nd gear during autocross.
My first oem clutch without autocrossing wasn't replaced till 120,000 miles.
Would be in for a group buy, but not sure I can wait that long.
Old Jun 23, 2016 | 11:47 AM
Former Sponsor
Group Buy ends tomorrow! We continue to stock the best clutch kits on the market for your TL/CL/Accord!
Old Jun 30, 2016 | 12:00 PM
Former Sponsor
While our group buy has ended, we still have great pricing on our clutch kits!
Old Jul 6, 2016 | 11:55 AM
Former Sponsor
PM us for the a custom quote shipped to your door!
Old Jul 20, 2016 | 09:53 AM
Former Sponsor
We have clutch kits in stock and ready to ship!
Old Aug 4, 2016 | 12:57 PM
Former Sponsor
We can price out just clutch kits without flywheels for anyone that is interested! PM us with what kit you need and your zip code for a full quote!
Old Aug 9, 2016 | 09:36 AM
Former Sponsor
Check out the multiple positive reviews on our clutch kit which you can find right in our 3G TL sale thread!
https://acurazine.com/forums/3g-tl-p...ilable-929663/
Old Aug 26, 2016 | 12:10 PM
Former Sponsor
Put the power to the ground with one of our XLR8 clutch kits!
Old Sep 9, 2016 | 02:09 PM
Former Sponsor
We offer our clutch kits with and without flywheels! PM us for a custom quote!
SidhuSaaB
May 30, 2020 12:40 AM
LeVeL
Oct 18, 2015 04:19 PM
Kres43
1G RDX (2007-2012)
Oct 3, 2015 07:16 PM
ExcelerateRep
Sponsored Sales & Group Buys
Sep 22, 2015 10:39 AM
