Need help identifying a noise
Old 01-26-2014, 03:23 PM
kcarr91's Avatar
I was hoping if someone knew what the cause of this sound is. I have taken the car to the dealership twice now in the past week to try to fix it with no luck. I will be taking it back tomorrow but i was hoping someone here might know what the problems is bc they cant seem to figure it out. I have a 2012 TL SH-AWD tech with ~25k miles. This noise only happens when i start the car after it has been sitting for 12+ hours and only happens 15 secs to 2 mins after start up and last about 30 secs then goes away. I describe it as a scribbling or a gargling, bellow is a link to the sound on soundcloud.
The dealership has already replaced the alternator belt and the belt tensioner adjuster, also the propeller shaft but that was bc another problem.
https://soundcloud.com/kcarr91/car-noise
Thanks!
Old 01-26-2014, 03:54 PM
3G TL/2G MDX Owner
TLtrigirl's Avatar
never heard anything like that in a car...is this from inside the car? i would assume so since there is no apparent engine noise. where exactly in the car does it seem like it comes from? sounds like bubbles...
Old 01-26-2014, 03:56 PM
kcarr91's Avatar
It seems to be coming from under the hood possibly drivers side.
Old 01-26-2014, 04:36 PM
irishbrahmin's Avatar
Perhaps air (bubbles) trapped in the cooling system?
Old 01-26-2014, 06:17 PM
'20 TLX SH-AWD A-Spec
Tonyware's Avatar
Sounds a bit like a pigeon? Transmission filter under battery tray... (I think?) Here is the link: https://acurazine.com/forums/4g-tl-problems-fixes-297/weirdest-sound-ive-heard-car-880507/ (near bottom of first page).
The dealerships should be reading acurazine once in a while
Old 01-26-2014, 06:32 PM
jayare627's Avatar
Remote transmission filter, underneath battery. Same issue with my car 2012 AWD.
Old 01-26-2014, 07:55 PM
kcarr91's Avatar
Thanks guys without your help they probably would not have been able to figure it out
Old 01-27-2014, 04:51 PM
Tonyware's Avatar
Well, at least you got a new belt and tensioner. Those tensioners tend to rust and get the belt out of alignment when it gets too too cold, and make more funny noises. So you got a new one
Old 02-07-2014, 03:17 PM
Viper45's Avatar
mine is in there at the dealership right now for the same reason...the same chirping type sound. they said that the sound is coming from a tensioner that is rubbing against the plastic shrouds under the hood from the timing belt is what they are saying...I was finding that it would only happen when I was at a stop and the car was cool...just got my car 2 months ago...so it better be fixed for free...I have full warranty..
Old 02-07-2014, 06:38 PM
arek1200's Avatar
Yes,it is external transmission fluid filter under the battery tray,had it replaced two months ago....annoying noise is gone....
Mista (02-26-2020)
Old 02-09-2014, 06:36 AM
rthammer's Avatar
I was told by the dealer the gargling sound is the brake master cylinder priming in cold weather.. (start up ) More of a noise issue then a problem. have you dealership call the tech line
Old 02-09-2014, 08:11 AM
arek1200's Avatar
your dealer is feeding you BS......
Old 02-10-2014, 03:29 PM
Viper45's Avatar
ok...so after 5 days of being at the dealership, they called me after me telling them about the tranny fluid filter, and said it was exactly that....so they have the car for one more day. on a bright note, not going to complain about having the SH AWD for a few days and using their gas....lol
Old 02-10-2014, 07:17 PM
arek1200's Avatar
6 days ?!!!? that dealer sucks!!!
Old 02-10-2014, 07:53 PM
3G TL/2G MDX Owner
TLtrigirl's Avatar
^^does it really matter how long they have it as long as they fix the problem? now they know what it is should another one come in with this noise.
Old 02-10-2014, 10:07 PM
arek1200's Avatar
it does matter how long they keep it... it was a simple issue and it took an "authorized dealer" 5 days to find the problem!!!! and they were told what the problem was....please...!
Old 02-10-2014, 11:12 PM
jackson94526's Avatar
Thanks!
Mine just started doing that a month ago. I have the same car, same year with 72000 on it. I had the exact sound from my previuos audi and it couldn't be solved. I hope you figure this out because after the car is warmed up it goes away...tough to have a dealer listen for it unless they keep it overnight.
Old 02-11-2014, 08:37 AM
arek1200's Avatar
I left my car at the dealership overnight, went there first thing next morning and went for a drive with a technician(radio off, fan off...) he could hear it loud and clear...the next day car war fixed and ready to go....
Old 02-11-2014, 04:55 PM
Viper45's Avatar
they were fine...they gave me a 2014 sh-awd for 5 days on their gas...no complaints....the reason they took so long to find it is they are a small local dealer....they hadn't even heard of this issue here before. oh well no complaints!!! thanks again for the help....if it wasn't for you guys, they would still be looking!
Old 06-24-2014, 11:19 AM
jim_c's Avatar
My car does not have the filter (it's a '10) but I'm curious.
Do you know why the filter made that noise?
Is there a drain back valve missing or something, so the fluid drains back to the pan while it sits? Will the new filter do the same thing eventually, or did they redesign it to prevent the drain back?
Thanks for posting about this.
Old 01-14-2015, 07:36 PM
Forum Contributor
EE4Life's Avatar
Received 1,392 Likes on 644 Posts
TSB 14-049 - Gurgle or Chirp from Under Hood at Cold Start-Up
Applies To: 2012-14 TL - ALL with A/T - ALL
http://www.urvi.net/forumfiles/SB/B14-049.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B14-049.PDF
The following 6 users liked this post by EE4Life:
Cito4jc (05-14-2015), cvc2013 (02-04-2015), fryrice (07-16-2015), jayroc76 (05-17-2015), Mista (02-26-2020), OttoCycle (06-20-2015) and 1 others liked this post. (Show less...)
Old 02-04-2015, 02:57 PM
cvc2013's Avatar
cold start chirp
The same chirping noise on cold start, read your post and SB-14-049. Dealership fix on 2-3-2015, thank-you for the great tec info. my 2013 TL FWD with 9000miles like new again
MrHeeltoe
20
02-23-2023 01:54 PM
SexyRL
4G TL Problems & Fixes
08-19-2016 10:03 PM
xsilverhawkx
10-05-2015 11:00 AM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
Quick Reply: Need help identifying a noise
