Front end noises when going over bumps
Old 06-11-2012 | 03:13 PM
RiddickRDX's Avatar
5th Gear
Hi there,
My first post here.
I have a 2008 RDX. When I drive over bumps in the road, be they potholes or just uneven surfaces, I hear noises coming from the front of the car. From the inside of the car, it sounds like a knock. From outside (heard when windows are open) it sounds more like a clank. (I hope that makes sense.)
Here's the interesting part: When I apply the brakes when driving over the bumps in the road the noises stop. I've had the car looked at numerous times by my dealer and no one seems to know what is causing these noises.
Other threads I've read here on Acurazine indicate it may be a loose brake caliper, engine mounts or shocks, etc. No one else has indicated that application of the car's brakes results in the noises stopping.
Does anyone have any ideas on what is causing these noises?
Thanks in advance.
Old 06-11-2012 | 04:39 PM
DRR98's Avatar
Check everything around here^. Sounds like maybe the top mount for the shock. Check that all fasteners are tightened to spec.
One side or both?
Old 06-11-2012 | 05:32 PM
RiddickRDX's Avatar
5th Gear
The sounds are coming from both sides. It really sounds bad, like something is about to fall off (but nothing ever does fall off thank goodness)!
Old 06-11-2012 | 06:12 PM
DRR98's Avatar
Did the pic go missing?
Old 06-11-2012 | 07:16 PM
RiddickRDX's Avatar
5th Gear
I guess it did. I didn't see a photo with your response.
Old 06-12-2012 | 01:44 AM
DRR98's Avatar
Can you see the pic now?
Old 06-12-2012 | 11:31 AM
RiddickRDX's Avatar
5th Gear
Unfortunately no. Can't see the pic.
Old 06-12-2012 | 12:51 PM
DRR98's Avatar
Not one to give up easy...
Ha, Thats what I thought I had...
Old 06-13-2012 | 08:10 AM
08FLrdxSH-AWD's Avatar
KCCO
I have very similar problems with mine but its only when its cold outside and when the car hasnt really warmed up yet. Took it to the dealer multiple times on the issue and they have come up with every excuse why its happening, anywhere between my roof rack cross bars being loose to my back seat being loose. So i finally got fed up with it and asked a good friend of mine who is a former Honda Tech and he said that its actually a common problem they dealt with on Honda's that they brought in to his shop and the problem is also not a rarity in Acura's (Acura just doesnt like to admit faulty suspension construction apparently). What he has told is that these cars tend to have bad front strut assemblies and that the bushings tend to act up in cold weather or when the car just isnt warmed up. I will check back with him on where you can go to verify this and present that info to an Acura dealership, which should get your issue fixed.
zerogravity (06-13-2012)
Old 06-13-2012 | 06:44 PM
zerogravity's Avatar
^ I also have this issue only in cold weather
Old 06-14-2012 | 03:37 PM
KCCO
I will talk to my buddy about what company to go through for these problems. I will post that up on this thread when i get the info it seems we all need
Old 06-14-2012 | 03:53 PM
RiddickRDX's Avatar
5th Gear
Thanks for your input. At my dealer's suggestion, I had the struts replaced earlier this year. However, the noise persists. (!!!!) I have an appointment on Saturday to have them look yet again based on the suggestions received in this thread.
Old 06-14-2012 | 05:47 PM
KCCO
Well thats great to hear that we are making a difference somewhere. My deler said that they wouldnt use this as a reference because its not an official, accredited, acura bulletin
Old 07-19-2012 | 05:20 PM
windowlickingood's Avatar
I would check the brake rotor cover and make sure all the bolts are tight. dont just shake and play with it. This was the fix for my similar issue.
Old 07-20-2012 | 06:24 AM
wspy's Avatar
2008 Acura RDX
Check the sway bar assembly/bushings.
Old 09-27-2012 | 10:05 PM
ludecraze93's Avatar
i was having the same problem.
dealership told me this noise was my brake pad, they confirmed by placing a shim behind the pad itself and recommended new pads (even though they are new) and a new hardware kit (pad retainer clips)
so im letting it go until i need new pads.
02tljj
09-11-2015 12:37 PM
08 NBP TL
09-08-2015 08:49 PM
Quick Reply: Front end noises when going over bumps
