Anti-Fouler
Old 03-07-2008, 09:53 PM
gfd1182's Avatar
Anti-Fouler
Can someone please explain to me what an anti-fouler is? I have the RT cat and keep on getting a cel i've tried everything and it still comes back on. I've been reading people have done an anti-fouler and resolved the prob. but what is it?
Old 03-08-2008, 07:12 AM
feuss2's Avatar
When you say you've tried everything, what have you done so far?
An anti-fouler is a spacer that is intended for use with spark plugs to stop them from fouling. If you drill out the middle you can use one or 2 of them to get your O2 sensor away from the exhaust which usually surpresses the CEL. In fact, people have used this trick to run test pipes...
http://shockerboys.20.forumer.com/viewtopic.php?t=195
Old 03-10-2008, 10:17 AM
gfd1182's Avatar
thanx alot. this is a big help! im gonna try this as soon as the weather gets warm
Old 03-18-2008, 08:59 PM
feuss2's Avatar
Weapon R CEL Eliminator
Old 03-20-2008, 08:18 AM
gfd1182's Avatar
this site is great help. thanx for the input.
Old 03-20-2008, 10:31 AM
moda_way's Avatar
This is a little obvious if you have emissions checks. The Anit-fouler MIGHT make it past an inspection.
Old 03-21-2008, 07:11 AM
feuss2's Avatar
Both parts (above and the RT Cat) are polished stainless. After some driving they would look like a pretty good match!
Old 03-21-2008, 11:23 AM
T.DoT P.I.M.P. lol
chuson's Avatar
I've tried an anti-fouler, and also one looks like the Weapon R in L-shape. Both give me CEL after a long period of time.
Old 03-23-2008, 09:16 AM
boost owns
Audioserf's Avatar
I think what modaway meant is the Weapon-R piece is a very obviously non-stock shape. The standard anti-fouler can blend in easier since it's a short straight piece.
Old 06-09-2008, 12:45 PM
moda_way's Avatar
I installed my anti-fouler purchased from Autozone. After drilling down, not all the way through, with a 1/2" bit to provide clearance (thanks for the advice JTso), no CEL for 24hrs.
Old 06-09-2008, 01:15 PM
Time to Climb
godfather2's Avatar
moda, didn't know you had issues with any CELs as of late ... please explain?
Old 06-09-2008, 01:53 PM
moda_way's Avatar
Oh, just kicking a CEL since winter when they started with the oxygenated gas shyte they put in here. Well, the CEL went off and it was associated to the 2nd O2 sensor stating the cat wasn't running efficiently. Absolutely not concerned about it since high flow cats are doing minimal work on the exhaust gas. Took the TSX out for a quick run up to 120mph for 2 miles of mostly untraveled highway here (flew past a TL Type S, thought maybe he'd try to run me down) and then ran it on a traffic packed highway this morning... still no CEL.
Old 06-09-2008, 02:34 PM
Time to Climb
godfather2's Avatar
i see, from your previous post i was under the impression that something mechanical may have been out of order
Old 06-09-2008, 06:20 PM
Rep'n Taxbrain.com
Tsx536's Avatar
Chuson, did you drill all the way through? I drilled mine just like Moda_way mentioned and never got CELs after that.
Old 02-11-2009, 02:42 PM
2006 ASM tsx
vthree's Avatar
if using the spark plug kit from autozone, do you have to drill it? I saw in another thread that moda said the o2 sensor would bottom out.. but mine fit in just fine.
Old 02-12-2009, 06:51 AM
boost owns
Audioserf's Avatar
I originally tried using the spark plug defouler from Autozone, and my 02 sensor most definitely did not fit - it bottomed out. I ordered a pre-drilled defouler from some muppet on eBay and that worked fine, no CEL since installing that about a year ago. No drill, no workbench = I'll be damned if I could have done it myself.
Old 02-12-2009, 03:51 PM
2006 ASM tsx
vthree's Avatar
hmmm.. im thinking about just filing down the inside of the second piece... i did indeed get a cel when i made a slow turn into an uphill driveway to sonic....
odd...
Old 02-12-2009, 04:01 PM
2006 ASM tsx
vthree's Avatar
sigh i hope after boring this out.. it stops.. i've been skimming other forums and they're saying that 06+ = trouble.. even with 4 adapters and a anti-fouler.. LOL. god i hope i have more luck than they did...
Old 02-12-2009, 05:49 PM
boost owns
Audioserf's Avatar
One single anti-fouler should be all you need. I can't think why you'd persist in having problems, it's not like this is a testpipe or anything. What other forums are these? I know of one... no other forums are particularly qualified to speak about the TSX.
You should be all set.
Old 02-12-2009, 06:22 PM
2006 ASM tsx
vthree's Avatar
hah.. well believe it or not i did not have a 1/2" BIT!!!! grrrrr. i only had 1/4... lol. so i tried to file the rest... i'm gonna go buy a 1/2" bit now.. garage space at my parents house sucksssss.. i miss my apt garage... also the other forums were s2k forums.. and rsx forums that did the same exact mod... i'm already so close. i'm just going to buy the 1/2" bit and do it again tomorrow...
i almost broke down and bought one off ebay like you did audioserf.. but i figure i maybe able to use the bit later so might as well not waste any more money. wish me luck tomorrow!
Old 02-13-2009, 12:35 PM
2006 ASM tsx
vthree's Avatar
hmmm so i got the bit early this morning. oh and last night when i reset the ecu.. there's a pretty big difference in how my ecu responds... way better w/o the light on. duh...
anyhow redrilled this morning... and drove up to autozone to buy a bulb.. after leaving autozone i decided to do a quick 0-60 or so... when i came to a stop... i got a cel.. grr... got in my garage checked again.. p0134.... any ideas?
did you guys use the lil washers that came with the anti foul kit?
Old 02-13-2009, 01:35 PM
Unregistered User
valeratj's Avatar
^ I got my defouler from an exhaust shop for $10, drove about 20 miles so far and no CEL. I just need to wait and see
Old 02-13-2009, 01:42 PM
LukeaTron's Avatar
You may want to look into the electronic CEL eliminators. It's a little box that splices into the O2 sensor wire and electronically modifies the signal to put it where the ECU wants it to be. I have no first hand experience with these though.
JTso
64
04-13-2010 01:18 AM
Pseudomaniac
07-08-2009 01:26 PM
DAYTA
06-10-2009 03:12 PM
feuss2
20
05-10-2009 05:52 PM
Quick Reply: Anti-Fouler
