Anti-Fouler
Anti-Fouler
Can someone please explain to me what an anti-fouler is? I have the RT cat and keep on getting a cel i've tried everything and it still comes back on. I've been reading people have done an anti-fouler and resolved the prob. but what is it?
When you say you've tried everything, what have you done so far?
An anti-fouler is a spacer that is intended for use with spark plugs to stop them from fouling. If you drill out the middle you can use one or 2 of them to get your O2 sensor away from the exhaust which usually surpresses the CEL. In fact, people have used this trick to run test pipes...
http://shockerboys.20.forumer.com/viewtopic.php?t=195
boost owns
I think what modaway meant is the Weapon-R piece is a very obviously non-stock shape. The standard anti-fouler can blend in easier since it's a short straight piece.
I installed my anti-fouler purchased from Autozone. After drilling down, not all the way through, with a 1/2" bit to provide clearance (thanks for the advice JTso), no CEL for 24hrs.
Originally Posted by godfather2
moda, didn't know you had issues with any CELs as of late ... please explain?
boost owns
I originally tried using the spark plug defouler from Autozone, and my 02 sensor most definitely did not fit - it bottomed out. I ordered a pre-drilled defouler from some muppet on eBay and that worked fine, no CEL since installing that about a year ago. No drill, no workbench = I'll be damned if I could have done it myself.
boost owns
One single anti-fouler should be all you need. I can't think why you'd persist in having problems, it's not like this is a testpipe or anything. What other forums are these? I know of one... no other forums are particularly qualified to speak about the TSX.
You should be all set.
2006 ASM tsx
i almost broke down and bought one off ebay like you did audioserf.. but i figure i maybe able to use the bit later so might as well not waste any more money. wish me luck tomorrow!
2006 ASM tsx
hmmm so i got the bit early this morning. oh and last night when i reset the ecu.. there's a pretty big difference in how my ecu responds... way better w/o the light on. duh...
anyhow redrilled this morning... and drove up to autozone to buy a bulb.. after leaving autozone i decided to do a quick 0-60 or so... when i came to a stop... i got a cel.. grr... got in my garage checked again.. p0134.... any ideas?
did you guys use the lil washers that came with the anti foul kit?
You may want to look into the electronic CEL eliminators. It's a little box that splices into the O2 sensor wire and electronically modifies the signal to put it where the ECU wants it to be. I have no first hand experience with these though.
feuss2
20
05-10-2009 05:52 PM
Tsx536
07-08-2008 12:20 PM
