Ct-e icebox lid rubbing on hood....
I like cars.
Anyone else have this problem? The insulation under the hood is rubbing on the cf lid of the icebox causing it to damage the finish.
The insulator rubs on a tiny spot of the piping on my AEM.. Thickest hood insulator I have had on any car if any. Really contemplating ripping that shit out its starting to look nasty
I like cars.
Yeah, it is pretty thick. I can see it crushing quite a bit on the cover when i close the hood. I thought about ripping it off or just getting rid of just that section but the car is still to new to me. Maybe ill just put some clear vinyl on the cf cover.
Username 0 (07-05-2015)
I like cars.
Very minor issue, yes, but an annoying one that will eat at you whenever you drive the car. considering how much this intake is, this shouldn't be an issue and removing the hoods insulation or even cutting around it would be unaccepted since this is not a cheaply engineered intake.
I like cars.
^its like you're not using your brain...
when you install something other than OEM, it WILL BE LESS RELIABLE. whether it be fitment or performance issues....
to solve your issue, simply remove the useless under hood insulation. no more rubbing. no more complaining. no more time wasted on how you can solve this issue.
Harper (07-06-2015)
I like cars.
Must be a slow day for you at your bridge. Your acting like the Justin Timberlake of Japan.
Now run along be a cocky dick hole some where else.
This thread is for icebox users that can weigh in.
This thread is for anyone that wants to post in it. None of this is your intellectual property including threads you start. IB owns it. Shocking, I know.
Anyway, it's the truth, what is your goal? To find a "solution"? The solution is to put the stock intake back in since it was designed to work with the hood insulation and have perfect clearance. Although I do agree that when you pay a lot of money for a modification, you expect to not have to make any adjustments, that's often not the case. If you contact CT-E about a little chaffing you're getting...I'd be shocked if they don't reply with "where exactly are you chaffing, sir"?
The following 3 users liked this post by rockstar143:
Jaheri_cbp (07-06-2015)
I like cars.
I never said this is my intellectual property. This thread is open to anyone, of course, but if you don't have this intake then well you are only speculating. I don't care who owns this thread, lol I just want to hear what other ICEBOX USERS have to say.
YES, I can remove the insulation or modify it. That's called common sense, not thinking outside the box. However, I will only do that if there are no other solutions or tips from OTHER ICEBOX USERS.
I have contacted ct-e, but in the meantime I would like to hear from other ICEBOX USERS.
Whats the point of putting stock parts into my car and posting here?? lol
Well, honestly, if the CT is touching the insulation, and someone figured out a way to make that stop happening, I'd be happy to hear it...just because it doesn't sound like there'd be another way.
I'm assuming there's no mounting bolt that would allow a little vertical play? Meaning you could unbolt and move the entire assembly down a smidge just so it doesn't touch? For us 3G guys, the heatsoak was so intense removing the insulation to allow better hot air venting under the hood was actually a great thing for us.
What's the finish on the CT box? CF with clear on it? I bet a hand buff with polish will bring the shine back...or maybe place some sort of sticker or even a clear furniture anti scratch pad there to kinda press the insulation up and off the box?
Just some ideas.
Just some ideas.
Now you're just being an snide ahole.
I listed 2 possible solutions. I'm assuming your retort means you think they're not suitable?
So, you don't want discussion or solutions. You want a thread where only tsx owners with iceboxes that might or might not have this issue stroke each other off?
I like cars.
KY jelly helps ridiculously well when it comes to chafing for me. Or if you want to go the organic route, virgin coconut oil does the job in a pinch and you smell like coconuts all day. Highly recommend both.
ROTAREDOM
Did you get the SC yet?
Guys... you're starting to hurt my feelings.
ROTAREDOM
I still wanna find out how much my engine is moving. I think that might be my next video. Is the hood pretty easy to remove?
No dampers.. Only on v6
Everyday I'm rofling
