ATLP OR XLR8 J-pipe?
Old Feb 14, 2015 | 01:03 PM
DjAirforce1's Avatar
9th Gear
Any clue on how which one is better? not sure where to start.
Old Feb 14, 2015 | 03:19 PM
carbonTSEX's Avatar
The Original Shawdy
Well that depends on if you're awd or fwd and if you're emissions check undercarriage or not. ATLP makes the V1 which retains the factory cat. But only offer the V2 for FWD which deletes the cat as well. Correct me if I am wrong please.
XLR8 offers both versions for both models. I went with XLR8 V2 for my AWD.
Old Feb 16, 2015 | 12:17 PM
MrHeeltoe's Avatar
Former Sponsor
Just adding in, not quite accurate on the ATLP data there.
V1, V2, V3...do not mean all the same things on all manufacturers.
The ATLP pipe made for the FWD TL is a V2 pipe (ATLP designation for increased ground clearance). ATLP never made a V1 for the 4g. All ATLP V2 pipes retain the factory 3rd cat and can be supplemented with a 3rd cat delete or high flow replacement.
XLR8's V1 design uses the cross-over primary and keeps the stock cat in place, while their V2 has inline primaries, more ground clearance, and deletes the 3rd cat without a supplementary pipe.
Old Feb 16, 2015 | 01:28 PM
ExcelerateRep's Avatar
Former Sponsor
I haven't heard the ATLP in person, but our V2 sounds great and adds a nice deep rumble. It's also made in the U.S. with U.S. grade stainless steel. Deleting the third cat will also free up a good amount of power, and since the third cat is not monitored it won't throw a check engine light.
Old Feb 16, 2015 | 04:08 PM
Schu's Avatar
Are there any dyno plots with before/after installs? Specially those with the cat delete...
Old Feb 16, 2015 | 04:58 PM
Former Sponsor
We have a dyno comparison of a 2007 Acura TL-S that is stock with just an intake vs with our V2 J-Pipe. I already know what Marcus thinks, but I'll post it here for you anyway.
Old Feb 16, 2015 | 11:05 PM
MrHeeltoe's Avatar
Former Sponsor
Here are the comparisons we have made of all the j-pipes together. It will show that the V2 makes more top end power for better high-performance applications, and the ATLP V2-R matches the XLR8 V2's power band.
https://acurazine.com/forums/perform...gether-923397/
The XLR8 V2 is a great pipe but don't for a second think any j-pipe will improve the engine's torque output that much. The dyno Excelerate is posting has big bold letters showing misleading information. It was done before the flashpro existed to the timing could definitely play a factor. According to what we know, it was a test submitted by a customer, leading to questionable test conditions.
Old Feb 17, 2015 | 08:10 AM
Schu's Avatar
I beleive in Churches...
Old Feb 23, 2015 | 06:24 PM
TheMuffinMan's Avatar
I've been debating myself, and the one thing I can't wrap my head around is:
- XLR8 V2 has 2.25" primaries w/ a 2.75" collector
- RV6 V2 has 2.25" primaries w/ a 3" collector
- ATLP V2 has 2.25" primaries w/ a 2.5" collector
But then:
- XLR8 exhaust is 3" to dual 2.5"
- ATLP exhaust is 3" to dual 2.25"
- Stock is ???
Wouldn't you want the collector to match to the exhaust?
Old Feb 24, 2015 | 08:38 AM
Schu's Avatar
Most of the magic, if there is any, is already accomplished at the burns collector and forward... the only way you can really mess up the rearend is to constrict it so much that flow is restricted.
Old Mar 4, 2015 | 12:35 PM
illi adik's Avatar
In the same boat myself debating between these three. All mount of up to factory exhaust, correct?
Old Mar 4, 2015 | 01:34 PM
carbonTSEX's Avatar
The Original Shawdy
Yes they all mount up with factory exhaust.
Old Mar 5, 2015 | 07:12 PM
ej6sliver's Avatar
I had that debate.
I think XLR8 outperform ATLP.
Either way, I bought XLR8 from heeltoe.
I am extremely happy with my purchase, great pipe, super fast shipping (to Canada), perfect fitment
Old Mar 6, 2015 | 03:54 PM
Former Sponsor
Originally Posted by ej6sliver
I had that debate.
We're glad your enjoying it!
Old Mar 9, 2015 | 09:05 AM
MrHeeltoe's Avatar
Former Sponsor
- RV6 V2 has 2.25" primaries w/ a 2.5" collector
But then:
- Stock is ???
Not necessarily...this isn't a critical point. Also, you don't want to confuse collector size with the rear flange size.
The ATLP V2 J-pipe you are mentioning here is for a FWD, and that 3" ATLP cat-back is for an AWD model.
Are you positive the XLR8 AWD cat-back has dual 2.5" that seems like a lot...and overkill.
Old Mar 10, 2015 | 01:41 PM
Ah, yep you're right on the ATLP, I thought I had the right one!
With regard to the XLR8, I was basing it off the numbers I found on the internetz -
XLR8 Exhaust Systems - Excelerate Performance - Japanese and European Performance Specialists!!
In the notes:
XLR8 Stainless Steel Resonated Catback Exhaust (3" to Dual 2.5" to Dual 4.5" Double Wall Oval Tips)
It also looks like you changed the collector #'s for the RV6 one from my quoted post. Should be 3" - or is that what you mean with the collector/rear flange? It says 3.0" exit - why would that number change from 2.5" to 3" ?
Old Mar 12, 2015 | 06:58 PM
MrHeeltoe's Avatar
Former Sponsor
Are we talking about FWD or AWD stuff?
Old Mar 12, 2015 | 10:55 PM
AWD
You're right on the ATLP though, I had linked the FWD model. But the number difference was in my quoted post vs the actual post. You changed the RV6 header from 3" to 2.5"
Jul 16, 2017 07:33 AM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
ExcelerateRep
Oct 14, 2015 08:20 AM
08_UA7_Gr33k
Sep 27, 2015 01:56 PM
