Hi-Speed's race engine swap
Old 09-23-2015 | 09:48 PM
  #161
Hi speed's Avatar
runnin a little boost
I have been driving the car around to work a few times a week and decided to buy some new parts on my mission to switch over to the Flash Pro. Changed the oil last week after 200-300 miles and it was the darkest oil I have ever seen. The car is driving better and better each time I take it out but, the oil color and usage makes me think the rings are done. I installed my new turbo blanket and it really makes a difference in power and keeping temps down. The new turbo drain is working great, so I felt it was time to put the turbo blanket back on.
I ordered the wrong fitting when I replaced the drain line to the oil pan, so I used the old fitting and its leaking so I bought the correct angle fitting and will be installing it soon. Since the MS3 has the boost controller in it I bought a AEM boost controller and since my wideband is dead I bought a AEM wideband.
Old 11-21-2015 | 12:14 AM
  #162
Hi speed's Avatar
Engine out rebuild time.
Old 11-21-2015 | 06:21 AM
  #163
screaminz28's Avatar
Did it blow or just tired of some of the blowby? Did you ever switch over to the hondata?
Old 11-21-2015 | 08:31 AM
  #164
KN_TL's Avatar
Looks like my engine bay.....pulled everything out because of a tranny issue, going to push it into a temporary garage for the winter.
If the winter stays this mild, may be able to get it back together before spring.
Old 11-21-2015 | 11:49 AM
  #165
Hi speed's Avatar
I was just tired of the oil usage and black exhaust tips. My wideband was fouled by all the oil in the exhaust and I'm switching over to the AEM wideband and don't what to ruin it. The Hondata will go in once the engine is back in and ready for tuning. Moving the gray wire in the OBD port was a huge pain for the Hondata upgrade. I moved it the first time in the garage and put the wire in the wrong spot. Before having the engine removed , I pull the car into the driveway and got the gray wire in the right spot but, now the car would start since that is the immobalizer wire.
Trying to decide if pulling the twin disc clutch and gong to a spec stage 3+ clutch is a good idea before putting everything back together.
Old 11-21-2015 | 02:50 PM
  #166
Hi speed's Avatar
What issues are you having with your tranny?
Old 11-21-2015 | 05:11 PM
  #167
MonkeyTrucker's Avatar
Life Connoisseur
Hi speed, I thoroughly enjoyed reading your thread earlier today, I hope to see follow-up videos of your completed efforts.
Old 11-21-2015 | 07:48 PM
  #168
KN_TL's Avatar
1st and 2nd is whining badly. Everything shifts fine so I'm not sure exactly whats going on. It's louder and a similar sound to my straight cut 3rd/4th.
I should be able to work on it during the thanksgiving break.
Old 11-21-2015 | 09:49 PM
  #169
Hi speed's Avatar
Thanks, with so little activity in this thread I was starting to think I should stop updating.
I'm going to make some videos, need to make a mount for my phone.
Old 11-21-2015 | 09:58 PM
  #170
Hi speed's Avatar
Get it going, I have been terrorizing San Jose with the car in less than perfect form and putting Costco lengths on anything in sight. Too much fun, passing people like their on the brakes.
KN_TL (11-22-2015)
Old 11-22-2015 | 10:33 AM
  #171
thisaznboi88's Avatar
^ when will your car be ready? I'll be in SJ in Jan. Hopefully, I can get the ecu swap for hondata all straighten out.
ps. your deposit is coming back tomorrow.
Old 11-22-2015 | 01:33 PM
  #172
UTAH TSX's Avatar
I'm in for videos, My gopro knockoff (SJCAM 5000) records great video but the audio doesn't pick up any good sounds our cars make only droan, working on external mike so we can hear those sweet exhaust, spooling, blow off sounds
thisaznboi88 (11-22-2015)
Old 11-22-2015 | 02:36 PM
  #173
Hi speed's Avatar
I'm not totally sure, the car is back home minus the engine to sit while the machine shop does there thing. There were ridges in the inside portion ( closest to the middle of the V) of a few cylinders. I might need to use my block and that will add time lost while the Mach shop inspects and rejects the old block. I think to should be done by Jan.
Old 11-22-2015 | 05:32 PM
  #174
KN_TL's Avatar
Can you snap some pics of the ridges. Are they all on one bank or randomly distributed.
I wonder would have happened if I ran the pistons I bought off the shelf where the offsets would have been incorrect on one bank.
Old 11-22-2015 | 11:11 PM
  #175
Hi speed's Avatar
The block has already been dropped off at the machine shop, so I don't have any pics. With the heads removed I felt around in the few cylinders I could to see if I could feel any scaring or groves. It was only in 1 or 2 but, only on the top side closest to the valley. It Would be pretty hard to see in a pic, nothing too dramatic.
csmeance (12-02-2015)
Old 11-24-2015 | 11:25 PM
  #176
rockstar143's Avatar
I would like vids of you leaving people in the dust. You know, for science...
Old 01-06-2016 | 09:37 PM
  #177
Hi speed's Avatar
So I decided to buy a new block for my engine build. I didn't like the idea of thinning out the cylinders and for $650 I couldn't pass up starting with a brand new block. Next is ordering the Pistons and getting this thing put together.
As far as the $31 shipping I don't see how that is going to work but, I called the dealership and they said they would honor it.
Old 01-06-2016 | 11:24 PM
  #178
Nice!
Old 01-07-2016 | 07:48 AM
  #179
KN_TL's Avatar
I ordered mine from acuraoemparts in Fla, shipped to VT and it cost me something like $65. It comes in a small box strapped to plywood and isn't overly heavy. Mine came in the same truck all of my other goodies come in.
Are you or your builder going to take the time to measure and match the main and rod bearings? That was the longest ordeal for me. After determining if they are tight or loose, then ordering more and repeating the process.
I also asked Andy what skirt clearances he is running and he went with .0035" as well.
Old 01-07-2016 | 08:42 AM
  #180
Hi speed's Avatar
The engine builder will be handling the bearing size measurements, I know that was a huge pain during your build. My plan is to use your piston specs with slightly lower comp.
Old 01-07-2016 | 10:44 AM
  #181
gerzand's Avatar
ahem, MY spec. lol
Been running strong for 12k miles.
  #182
KN_TL's Avatar
I would suggest waiting for the block to come in before ordering the pistons. The compression height and valve pocket specs won't change, but the bore size could vary and you should have them measured to make sure your clearances are going to be correct.
Old 01-07-2016 | 04:05 PM
  #183
KN_TL's Avatar
Originally Posted by gerzand
ahem, MY spec. lol
True True
Old 01-07-2016 | 08:52 PM
  #184
Hi speed's Avatar
Good call, the block should be here next week.
Old 01-08-2016 | 07:40 AM
  #185
Dude...you're making up for all us dumbasses that pay $11 shipping for a $2 bolt
csmeance (01-12-2016)
Old 01-19-2016 | 10:36 PM
  #186
Hi speed's Avatar
The block arrived. Oemacuraparts honored the $32 shipping and never said another word. The plan is to take it over to have it measured so I can order the pistons. The bores look honed and have clear crosshatching but, I will have it measured just to be sure. So far the block looks perfect and I'm pretty happy with the the price and choice to go new. I can't believe this thing fit into such a small box and is only 70 something LBS, very cool to see it this broken down.
Old 01-20-2016 | 05:54 AM
  #187
KN_TL's Avatar
Very cool. I was told by the Acura folks that the block is ready to go. Just have to match up the bearings to the codes and do some measurements. They were pretty close but I decided to go a little looser so I ended up ordering, waiting, measuring, ordering, waiting measuring. In between got some that were nicked or scratched so I ordered again. They package and ship them like hard candy. No padding or protection at all.
I'd be interested in hearing what your builder uses for specs on bearing and skirt clearances.
Old 01-20-2016 | 12:13 PM
  #188
UTAH TSX's Avatar
Oooohhhh so shiney
Old 01-20-2016 | 12:40 PM
  #189
that nice!
Did you ever get the wiring issue figured out for your car?
Old 01-20-2016 | 07:36 PM
  #190
Hi speed's Avatar
that nice!
As far as the OBD port wire relocation, I'm pretty sure I found the right pins because the car wouldn't start anymore and it did when I pulled it out of the garage. My hope is that once the MS3 is removed that will allow the ecu to be flashed and get to tuning. I would like to keep the knock indicator led and hope it can be separated from the MS3.
Old 02-26-2016 | 07:22 PM
  #191
Hi speed's Avatar
Pistons shipped today, should be here 3/3/16. I ended up ordering from Wiseco and using KN/Gerands specs modified to a 9.5 compression ratio. I mentioned that I had Wiseco pistons in the engine when asked why I was rebuilding and the damage to the block. The guy gave me a returning customer discount and everything came to under $900 with coating and heavy duty wrist pins. I'm excited to get moving on this build and get the car back on the road.
The following 2 users liked this post by Hi speed:
gerzand (02-29-2016), thisaznboi88 (02-26-2016)
Old 02-29-2016 | 02:53 PM
  #192
gerzand's Avatar
It can. Its a standalone unit.
Old 03-03-2016 | 03:18 PM
  #193
Hi speed's Avatar
The Pistons finally arrived and they look amazing, very happy with fit and finish. I used KN's/Gerzand's specs with a slight dish to get the 9.5:1 compression I want. Here is some pics of the spec sheet and some to show the dish.
Old 03-03-2016 | 03:26 PM
  #194
Soo pretty. Is there a cut out for the oil squirters?
Old 03-03-2016 | 03:40 PM
  #195
Hi speed's Avatar
I don't think the j32 has squirters. Sure hope not.
Old 03-03-2016 | 05:43 PM
  #196
KN_TL's Avatar
J32 definitely does not have squirters.
Are the cuts equal on all 4 corners of the skirts? I know mine were and that might just be an optical illusion.
Old 03-03-2016 | 06:15 PM
  #197
gerzand's Avatar
Could you please weigh one of your S734 wrist pins and let me know the weight in grams, please?
Old 03-03-2016 | 06:43 PM
  #198
it does not, but it might just be the angle of the picture.
Old 03-03-2016 | 09:30 PM
  #199
UTAH TSX's Avatar
Those look good, much stronger looking than our broken JE pistons
Old 03-03-2016 | 10:00 PM
  #200
Hi speed's Avatar
All four valve reliefs are the same as far as I can tell. I think that's what you are referring to.
The weight is 115 grams.
Quick Reply: Hi-Speed's race engine swap
