NY/NJ New Jersey & New York
Looking to get a '98 RL fixed: need bunch of stuff done
Old Mar 14, 2012 | 12:54 PM
minghi's Avatar
3rd Gear
Hi, I'm inheriting an old '99 RL with over 200k on it and since I don't have time to work on it, I was hoping to find a good independent mechanic in Central NJ.
It has a bunch of issues except for the engine/transmission which are in great condition (oil changed regularly/transmission fluid flushed every 40-50k miles). Everything else is falling apart since my uncle never bothered to fix little things as long as the car kept moving.
To start with, it needs a timing belt/water pump change as the last time it was done was at 120k miles, then the CEL/SRS/ABS lights are on, its definitely a Christmas miracle that the car still drives lol. I'm guessing it needs new brakes all around since the rotors are warped. SRS is a seatbelt issue most likely which is very common on these cars. ABS light is on, not sure what it is? I've a ODB-II scanner and plan to get the codes for the CEL soon, how do I get the ABS/SRS codes?
What else would you change in this car so it will hopefully last a little longer.
1) Timing belt/water pump & other stuff
2) Transmission drain & fill
3) Bleed brakes
4) Coolant flush
5) Brake pads & rotors
6) Radiator hoses
LeVeL
Oct 18, 2015 04:19 PM
SUPRMN84
Oct 7, 2015 09:46 PM
swany0095
2G TSX Performance Parts & Modifications
Oct 7, 2015 02:18 PM
kb1rl
Sep 30, 2015 10:17 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
