RSX seemingly not going into gear, what's wrong?
Old Aug 30, 2013 | 07:33 AM
ixSLACKERxi's Avatar
Hello everyone,
I have an 04 Acura RSX Type-S. I was driving home on the highway yesterday using Cruise control going 70mph. I noticed my RPMs getting higher and higher which is normal when I'm going up a little hill and it's trying to maintain speed, but I noticed that it was going higher than normal and seemingly not getting any traction. I decided to just take CC off and drive but it was still seemingly getting no traction. I eventually realized that I was steadily slowing down and just coasting even while I'm in gear. I could put it into any gear I wish and nothing would happen. I pulled over and came to a stop. Put it into 1st gear and released the clutch and it did not budge. I could put my car into 1st, 2nd, 3rd, 4th, and reverse (Wouldn't let me put it into 5th or 6th) and it would do nothing. Something looked to be leaking from the bottom of my car but I'm not very car-savvy so I could not pin point what it was or what it was coming from, but I am smart enough to know that the smell was abnormal. I ended up getting it towed home. It starts just fine, it was driving fine with not apparent issues when this all happened. My cousin who is a master mechanic (Lives several states away so could not look at it), I told him the issues and he thinks it's my clutch and that it just gave out.
Do you agree? Or do you think it might be something else?
Any help would be awesome! Thanks guys!!
Old Aug 30, 2013 | 07:41 AM
2 issues here.
clutch
and low tranny fluid.
without looking at the car, making an educated guess, you damaged your tranny. which then started leaking. no to little fluid would make it hard to put it into gear.
when the RPMs climb and speed does not, thats the clutch!
Old Aug 30, 2013 | 10:05 AM
What do I do?
thanks for the reply
Old Aug 30, 2013 | 10:11 AM
well, first, you need to figure out what and where the leak is coming from.
if it is indeed the tranny, you'll have to patch up, replace tranny, or replace transfer case to tranny.
I cannot diagnose over the internet. its very hard. as, I am just assuming.
Old Aug 30, 2013 | 10:57 AM
It is not hard to shift, it's as easy to shift as it's ever been, but it just does not go into gear. I was outside looking at it, had my gf push the clutch in and out and I did not notice anything actually moving (I don't know if anything would move when the clutch is let in and out). But when I had her shift I could see the car shifting. She was shifting with the clutch out. I then started the car and it still would shift and the clutch seemed to do nothing
Old Aug 30, 2013 | 04:16 PM
Jeff122886's Avatar
Jeff
Originally Posted by ixSLACKERxi
Hello everyone,
2 issues here.
clutch
To me it sounds like a toasted clutch disc, I had a buddy who had his drain plug fall out and he drove for 10-20 miles with no fluid and had no issues.
First off, you are going to need to pull the tranny so you should start on that... I am pretty sure it would be the clutch from the way you described your rpms going up but no traction.
Old Aug 30, 2013 | 07:18 PM
Thanks for the reply Jeff,
I know very little about cars, I don't know what a clutch disc is, or how serious that may be. How bad is that?
Old Aug 31, 2013 | 12:05 PM
1black_seven's Avatar
Slot Machine Lubricator
It cost me $800 to change the worn clutch in my Saturn. I had a mechanic do it.
Old Aug 31, 2013 | 04:06 PM
Jeff122886's Avatar
Jeff
the clutch disc means you need to replace your clutch. You are looking at probably like 300-400 in parts and labor can be anywhere from 500-1000+ depending where you take it and how much they charge. I think the book says 8 or so hours of labor
Old Aug 31, 2013 | 08:05 PM
Thanks for the responses guys, I appreciate it. Hopefully I can find out more tomorrow when my gf's Dad takes a look at it, hopefully just to verify the issue so I can finally have a mechanic look at it and get a idea
Old Sep 4, 2013 | 08:42 AM
Hey guys,
My girlfriend's Dad looked at my car and he says it's the clutch, he says he could smell that it was burnt out. He says he's unsure if it would need a fly wheel as well because it would need to be open to know for sure
Old Sep 4, 2013 | 08:43 AM
What do I need to buy to replace the clutch? Also what about the fly wheel just in case?
Old Sep 4, 2013 | 08:47 AM
the thing that concerns me is that you said there was fluid leaking.
and that it will not go in gear.
this leads me to believe that the tranny is done as well.
tranny and clutch are two different things.
Old Sep 9, 2013 | 08:38 PM
My girlfriend's Dad looked at it and he says it's the clutch. As far as the fluid leaking goes, I think I was wrong, there was something coming from beneath my car but I'm pretty sure it was just the water from my AC.
What do I need in full for my clutch? Is the Clutch kit all I need to replace my clutch?
Old Sep 12, 2013 | 08:03 AM
knavekid's Avatar
Acura Fanboy
Clutch disk, pressure plate, throw-out bearing, possibly flywheel depending on its condition.
Old Sep 29, 2013 | 01:45 PM
How much should I be looking at price-wise to replace my clutch?
I know the labor part might be tough but what about the parts? I don't know if it's the Fly wheel but lets assume it's not, how much would that be? And if it is the fly wheel, how much may that be?
Old Oct 4, 2013 | 11:42 AM
BattleofXs's Avatar
clutch is a pain in the ass for the rsx, you have to drop the subframe, remove axle, and support the engine/trans on different jacks to get to it
here ya go homie
http://forums.clubrsx.com/showthread.php?t=718585
http://customdc5.my-php.net/diy/clutch/
Old Nov 1, 2013 | 08:36 AM
Thanks guys! Turns out it was the clutch, I got it replaced parts and labor for around $700.
UNFORTUNATELY the damn mechanic who did this, forgot to put the bolt back into the front engine mount and now the mount is broken from shifting around. So I'm dealing with that dumb issue.
Old Nov 26, 2013 | 04:01 PM
acurarsx04's Avatar
Asian Persuasion
I'm gonna be replacing the clutch in my 04 rsx type s. I'm getting an oem exedy clutch for $180 and then I may have to get my flywheel resurfaced for $25. The clutch I'll put in myself. Shouldn't take me that long. hopefully at the most 5 hrs. I work at shop. I have my own bay which helps.
Old Dec 2, 2014 | 09:35 AM
irishclover's Avatar
No gears after transmission swap??
After i swapped my transmission hooked it all back up i had no gears.. free flowing gear box. When you grab the stick you cant find any gear and it starts up in gear? Anyone know what my issue is? Rocker pin?
cycdaniel
Dec 17, 2019 10:58 AM
NitroViper
Mar 20, 2017 09:50 PM
vanderveen44
ILX
Sep 12, 2015 05:07 PM
phillyguerrilla
Sep 11, 2015 06:39 PM
HeloDown
Sep 8, 2015 06:51 PM
