DIY TL flip key chip intall
this is for the guys that got a Acura TL flip key that is converted to work for there RSX.
1. Take the key to a good locksmith and have it cut.
2. program the keys fob using this video
note: use the lock button then programing
3. cut the chip out of the your old key check out this link
http://forums..com/showthread.php?t=738545&highlight=
4.take the TL key apart all you need is a small phillips screw driver and super glue to hold the chip in place. watch this video
then you will see 3 small screws remove them in any order
the metal cover will twist off
remove the spring and the key
place the chip in the compartment and add glue. make sure the chip sit flush within the key head
after the glue is dry reassemble the key
be carefull not to over tighten the spring all it needs is a half turn
place the spring end into the smallest hole
make a half turn and tighten the screws
soupi
14
11-15-2015 11:15 AM
