2015 ILX 2.4L Build
Old 06-01-2020, 12:38 AM
visi_d's Avatar
2015 ILX 2.4L Build
Hey guys, so i can post pictures but i figured a video would work well also.
Day 1 at the dealership. Purchased used with about 46k on it.
clean over all car
Installed the aFe Takeda intake with their Pro5R Fliter. Cant see here but later also installed their TB Spacer
Removed the resonator that sits behind the driver side fog light.
Lowered the car on Tein S-Tech springs. Mild drop and overall good ride quality still. Also here i mounted 18 inch wheels on the car 18x7
Full Race downpipe with high flow CAT. Picked this up used from another SI owner
Full Race vs Stock
HASPORT Upper engine mount U62A
HASPORT Lower engine mount U62A
3M Wrapped the interior trim
Front OEM Aero Install time
Injen Axel Back install. Had to make a cut out for it to fit
Ebay universal diffuser
BRAUM Racing seats. Used Civic Si 9thgen seat rails to install them on the car. You will be able to hook up the seat belt connector back up but you will get the airbag light. Working on figuring it out to to fool the system.
much lower seating postion
different wheels, Drag DR69 17x7.5
Ebay door sill inserts
Caliper paint job using high temp primer, paint and clear
Time for some engine bling lol. Powder coated the valve cover to match the J's racing one. J's racing oil cap and plaque on the valve cover. Painter the oil dipststick black. Picked up a different coil pack cover. Also not able to see here is the Greddy radiator cap.
this wasnt the most fun thing to install
The following 3 users liked this post by visi_d:
Billy Sastard (04-10-2023), evmans (10-07-2021), lsimpson50 (11-27-2021)
Old 07-27-2020, 08:19 PM
5th Gear
Simpleilx's Avatar
nice build, car looks good
any turbo plans
Old 07-27-2020, 08:21 PM
Received 16,260 Likes on 11,971 Posts
Loved following your build over the years! here's to many many more years to come!
Old 07-28-2020, 12:47 PM
visi_d's Avatar
Thank you. I have much more to do on this car. Stay tuned.
Old 07-28-2020, 12:50 PM
visi_d's Avatar
any turbo plans
No turbo plans. I going to keep this car naturally aspirated. I just purchased an LSD for the car as well as exedy stage 1 clutch. This will really help the car around the track for me.
Old 02-16-2021, 05:50 PM
visi_d's Avatar
New wheels
Back for a little update on the car. So I sold the drag wheels I was running on the car to get these new ones. Wanted to go with a bigger offset and wider wheel. These are 17x8 with 35mm offset. Going to run a 245/40/17 on the car. The plan is to get some TL-S brembo calipers for the front and these wheels will clear the bigger calipers.
godfather2 (02-24-2021)
Old 03-22-2021, 11:45 PM
visi_d's Avatar
Painting the wheels
Decided to change up the color of the wheels since the finish was looking a little worn down. I had already mounted the new tires which meant more prep work. Also got these sand blasted before painting them which helped me start with a clean slate.
2 can of primer not shown here. 3 cans of paint and 2 clear. Also added the effex clear for a more metalic look.
Fresh decals and valve stem covers
Incase anyone wonders if I did the inside of the wheel 😉😉
justnspace (09-25-2021)
Old 03-23-2021, 05:19 AM
Time to Climb
godfather2's Avatar
looks fantastic, nice touch!
visi_d (03-23-2021)
Old 04-09-2021, 07:11 PM
visi_d's Avatar
Some new trim pieces..taking on a panda look
In love with how these wheels look on the car
Side aero trim piece. Gloss black
Front splitter fit pretty good. No cutting needed.bhard to see in pics but center section is gloss black and sides are matte black.
godfather2 (04-17-2021)
Old 04-18-2021, 02:59 PM
visi_d's Avatar
Strut bar installation 2013-2015 ilx
Must remove wiper arms to remove trim piece
Cut out on the trim you need to make for clearance.
Same cut out drivers side
Need to remove hood liner to have clearance when closing the hood.
Guys i will be posting a video for the installation soon. Please check it out.
Old 04-19-2021, 10:45 AM
visi_d's Avatar
DIY Video of the Install
Here is the link to the video. Thanks for watching.
Old 06-01-2021, 01:31 PM
visi_d's Avatar
Under body brace
Need to cut out two holes in the plastic at the rearward mounting area to expose the two bolts used to secure the brace in place.
godfather2 (06-01-2021)
Old 06-27-2021, 12:07 PM
visi_d's Avatar
Few more upgrades
A little hear management
Invidia exhaust
Oem 2.25"
70mm 2.75"
The top sticks out a bit but will be cutting a few inches off.
Installed
godfather2 (06-28-2021)
Old 07-26-2021, 09:56 AM
visi_d's Avatar
Billy Sastard (04-10-2023), godfather2 (07-26-2021), justnspace (09-25-2021)
Old 07-26-2021, 09:58 AM
visi_d's Avatar
A little fun on the the track at Western Michigan Honda Meet. This takes place at Gingermen Raceway, south haven Michigan. If anyone has the opportunity to come try your car out, DO IT. Amazing experience.
The following 2 users liked this post by visi_d:
GLOVE (08-02-2021), justnspace (09-25-2021)
Old 07-26-2021, 06:55 PM
Time to Climb
godfather2's Avatar
looks like fun. Thanks for sharing
Old 08-02-2021, 08:48 AM
5th Gear
GLOVE's Avatar
Like the above guy said ^^^
Thanks for posting! Wheels look great, I bought the same car last year and was wondering what gold would look like on her. 🤔
Old 08-05-2021, 07:45 PM
usdmJON's Avatar
Awesome progress. Not many care to track the ILX.
Old 08-08-2021, 07:23 PM
visi_d's Avatar
Some sway bar bushings upgrades
20mm front sway bar bushings from energy suspension
Old 08-09-2021, 12:28 PM
7th Gear
lsimpson50's Avatar
Looks great!
visi_d (08-16-2021)
Old 08-16-2021, 12:38 PM
visi_d's Avatar
Stop tech brake lines
Old 08-16-2021, 04:44 PM
visi_d's Avatar
Guide video
godfather2 (09-26-2021)
Old 09-23-2021, 08:56 PM
AustenwaK24z7's Avatar
Rear mount
ILX is sweet! Just bought one and i'm eager to start installing upgrades. I cant find anywhere online that shows the rear hasport mount to fit the ILX. Please help!
Old 09-24-2021, 10:11 AM
visi_d's Avatar
If you have the same ILX as me, you can get one for a 9thgen civic SI.
Old 09-24-2021, 01:20 PM
I figured, thanks for clarifying. Also not sure if you tuned yours yet, but I heard you talking about Ktuning it. I went with Hondata. Hondata doesn’t support the 15 ILX ECU, but you can get one from a 13 or 14 (part number 37820-R9B-A03 I got mine used off of eBay) and have your Acura dealer install and program it.
thanks again for your help.
visi_d (09-27-2021)
Old 09-25-2021, 08:29 AM
wow, love the bronze wheels and the front lip!!!!
amazing progress!!!
looks like you have fun with your car too! with all the suspension and stiffening of the chassis, how does she perform?
visi_d (09-27-2021)
Old 09-27-2021, 07:51 AM
visi_d's Avatar
amazing progress!!!
The car feels pretty good overall. The springs need to go if I wanna have more fun. The car definitely has more in it. Coilovers are coming soon.
Old 10-22-2021, 12:14 PM
visi_d's Avatar
New drivers seat
godfather2 (10-24-2021)
Old 11-09-2021, 12:15 PM
visi_d's Avatar
godfather2 (11-10-2021)
Old 11-10-2021, 08:03 AM
visi_d's Avatar
New drivers seat from Braum Racing.
Old 11-10-2021, 01:30 PM
visi_d's Avatar
DIY Video for seat install
Old 12-03-2021, 09:54 AM
visi_d's Avatar
Custom seat belt latch arm
So with the higher bolsters from the new seat, i ran into a small issue with the seat belt latch sitting really low between the center console and the seat. It was also pressing hard against the center console. Went to a local machine shop and had them modify the OEM latch arm to where they created and weld on a longer arm.
lsimpson50 (12-03-2021)
Old 12-04-2021, 04:51 AM
E92Vancouver's Avatar
To the OP! Wow bruh! Nice fawking job!!!
visi_d (12-04-2021)
Old 12-14-2021, 02:31 PM
visi_d's Avatar
Suspension overhaul project coming up
Parts are in. Ready for some upgrades and preventative maintenance.
Coilovers, new rear swaybar, turnk brace and many more small suspension components.
godfather2 (12-15-2021)
Old 12-28-2021, 05:05 PM
visi_d's Avatar
The goods
Rear is done, camber kit,swaybar and coilovers
godfather2 (12-30-2021), lsimpson50 (12-28-2021)
Old 12-28-2021, 07:12 PM
visi_d's Avatar
Fronts are in
godfather2 (03-01-2022)
Old 12-28-2021, 11:04 PM
visi_d's Avatar
Old 12-29-2021, 01:38 AM
visi_d's Avatar
The cut outs are for the rest strut bar going in. Also to have access to the shocks for adjustments.
Old 01-13-2022, 10:26 PM
visi_d's Avatar
More goodies
Dry carbon fiber
Little engine bling
godfather2 (03-01-2022), lsimpson50 (01-14-2022)
Old 02-28-2022, 01:02 PM
visi_d's Avatar
godfather2 (03-01-2022), lsimpson50 (02-28-2022)
Quick Reply: 2015 ILX 2.4L Build
