OSU Build Thread
Old Apr 19, 2014 | 09:22 AM
  #121
SlipAngle's Avatar
Originally Posted by OSUBeaver
Just got back from a 3 hour dyno session with vit. Baseline whp is 165ish on a bone stock 2.4l. Before tuning I was at 177whp. After tuning 191whp and 165 ft lbs. stock torque at the wheels is low 150's.
Rev hang gone, throttle response much much better. Best mod so far.
How is the part throttle power? Does the car feel significantly different from stock? I installed the RV6 last weekend and started tuning with Vit at the same time. We're at revision #4/5 right now. I normally do my own tuning but though it would be good to use Vit's services and see what I can add to my knowledge base.
Also curious as to how you find the sound with the RV6 - Is your's the catted version? I find it louder than stock and mostly OK but 2000 rpm hits a loud resonance that I would like to get rid of.. I will say this is based on my calibration being locked on the 0 cam so the sound may change as the tune progresses. Cam angle can make a difference in sound and I think 25* may produce the least amount of noise.
Old Apr 19, 2014 | 01:15 PM
  #122
OSUBeaver's Avatar
Do you have a cat-back system as well? Or just the RV6 catted downpipe? 2000 RPMs is extremely loud for me as well. Seems like it got louder after the tune. I have the catted version as well. Mid/low range gained about 7 ft lbs and 4 to 6 hp from 1500 to 5000 RPMs. Top gained 14whp and 7 ft lbs.
Overall it drives much smoother, more power throughout the entire power band, rev hang gone. Not like it feels like I gained 40hp but still noticeable.
Old Apr 19, 2014 | 08:58 PM
  #123
SlipAngle's Avatar
Stock exhaust for me. Stock intake as well. I think the RV6 is starting to get a bit quieter as it gets coated internally but I'll try to see what can be done to remove the 2000 RPM sound spike.
Does your RV6 make a tinny sounding rattle on start-up? Mine seems to for about a minute or less. Not loud but I notice it.
Old Apr 20, 2014 | 12:24 AM
  #124
OSUBeaver's Avatar
Hard to say, the whole system rumbles really loud on a cold start for about 20 seconds
Old Apr 21, 2014 | 05:43 PM
  #125
Triscuit's Avatar
Was that your car Vit posted in the ecu tuned section of 9th Gen Civic? If it was great numbers! When did Hondata release the '14 flash pro?
Old Apr 21, 2014 | 06:23 PM
  #126
OSUBeaver's Avatar
Yes sir. Didn't even see that yet. Flashpro was updated to work with the 14 ilx as of the first week of April. I've been waiting over a month since I bought that damn thing. Hondata's website said it worked for the 2014 ILX back in January but they were wrong. I guess I was the first to try it because it was the 1st time they heard it wasn't working.
Stripping the Intake, Downpipe and Exhaust off the car in May and going 3" piping and CAI for the Cte Supercharger install. #Pumped!
Old Apr 21, 2014 | 06:53 PM
  #127
usdmJON's Avatar
So sick!! Cant wait to see this happen.
It makes me sad knowing I cant go hondata... but it'll make it easier to be a leader when it comes to the 2.0
The hondata numbers look soo good. I can't wait to be able to tune mine!
Old Apr 29, 2014 | 03:20 PM
  #128
OSUBeaver's Avatar
Just ordered the following parts:
Dimpled and Slotted F/R Rotors
25mm Rear Spacers (will have 19mm F and 25mm R now)
Progressive 24mm Rear Anti-Sway Bar
FKX Rear Tie Bar (front is sold out but will order when in stock)
Full-Race 3" Catted Downpipe
Full-Race 3" Cat Back Exhaust
Putting on some more clear bra (Trunk, Roof, Gas Tank Area - We can't pump our own gas in OR and i don't trust anyone)
As soon as the DP + Exhaust is installed I will have the Bumper modified - have to take it off before the exhaust is installed then taking down to my guy's body shop for fab work. Will have the bottom piece painted black so it will not show any soot that shows up after the SC is installed this summer
Old Apr 29, 2014 | 03:34 PM
  #129
xdtownx's Avatar
Did you coat the downpipe? Im about to order the full race setup as well and dont know if I should coat it or not.
Old Apr 29, 2014 | 03:49 PM
  #130
OSUBeaver's Avatar
I did not, unless you are going to the track often or driving really hard on a regular basis you will be fine with stainless. My 2.5" is stainless right now and I've had no issues for 2 months. Your call
Old Apr 29, 2014 | 11:45 PM
  #131
SlaammedILX's Avatar
daaaaaaamn im jealous, I wont be boosting till the end of the year or next year :/
Old Apr 30, 2014 | 10:16 AM
  #132
OSUBeaver's Avatar
That's fine though, you'll still be one of the VERY VERY few people with a boasted ILX. To be honest I don't know of 1. I don't think Vit has ever tuned one either. You know anyone with a SC in their ILX?
Old Apr 30, 2014 | 01:01 PM
  #133
usdmJON's Avatar
The only FI ILX so far is the Endurance ILX Acura or some company put together. So far no privately owned ILX is FI... turbo or supercharger.
I doubt a supercharger will be developed for the R20... not sure if one was created for the R18 civic. If so Ill check that out because Id like to go supercharger being a daily driven car. But if turbo is my only option... so far it is already available, than Ill go that route and run at low boost settings. Maybe 7-8psi.
Old Apr 30, 2014 | 04:51 PM
  #134
OSUBeaver's Avatar
I believe Jackson Racing made a supercharger for the R18 a year or 2 ago.....can't say for sure
Old May 1, 2014 | 03:24 PM
  #135
Timmy18's Avatar
They have one. Impressive numbers too.
https://jacksonracing.com/jackson-ra...stem-released/
Old May 1, 2014 | 04:36 PM
  #136
usdmJON's Avatar
If those are stock numbers on the carb system i would be VERY happy with those numbers. being that the r20 is larger I wonder if Id see something past 210hp with the extra .2L
As well with some further modding 250hp could be quite possible.
At $3500 before tuning options that does seem a bit step compared to the Turbonetics turbo kit before tuning.
Old May 1, 2014 | 06:22 PM
  #137
OSUBeaver's Avatar
Definitely can't be bone stock. The R18 only came stock with 140hp at the engine (should be at most 120hp at the wheel) and this one is showing 142hp. Probably had full bolt ons and professional tune.
Old May 1, 2014 | 06:32 PM
  #138
usdmJON's Avatar
I hate when companies show dynos on non stock cars.
Or maybe they ran an engine dyno? Can they do that while the engine is in the car still?
We only ran engine dynos while they were on a hoist.
Old May 3, 2014 | 12:42 AM
  #139
There are only 3 ILX's that I know of 100% are boosted but they were all SEMA cars. The endurance one, Street one, and the vinyl wrapped gold one. Ive been pondering through IG and I believe someone is running a S/c on there ILX but then again he was posting pics of a S/C'd 8th gen also. Im pretty sure somewhere out there theres a boosted one, just not on the internet yet.
BUUUUT.. you still beat me to it haha. Cant wait to see your numbers !
Old May 3, 2014 | 10:13 AM
  #140
usdmJON's Avatar
Are you sure the street build was fi?
I only mentioned the endurance because I thought the street build was NA... totally forgot about that gold one.
Old May 3, 2014 | 01:08 PM
  #141
Timmy18's Avatar
Well those cars weren't 2.0L AT's...
Old May 3, 2014 | 02:53 PM
  #142
usdmJON's Avatar
No one ever said they were... There are1.8L ATs. Same motor as mine .2l smaller. Same shit thanks timmeh.
Old May 4, 2014 | 02:52 AM
  #143
pretty sure the street one was, they rated it at 250whp and that aint possible with just bolt ons. AxionIndustries produced a z7 with 210ish whp with the rbc conversion, rdx injectors/tb, skunk2 alpha header, skunk2 fuel rail, and not sure which exhaust.
Old May 4, 2014 | 08:13 PM
  #144
Timmy18's Avatar
My point was those gains were likely made on 5 speed's, not AT's, so that could be why the HP/ TQ figures are so much higher than we expected. Of course tune+ other shit helps out.
Old May 5, 2014 | 05:59 PM
  #145
usdmJON's Avatar
Well from what I see on Hondata's site as well as the site for the jackson supercharger and tsi turbo all say they are for the MT and AT while not mentioned either being specific but always mentioning the gains made so one would assume the numbers to be comparable AT to MT being the same motor. In the end, it is the motor we're talking about.
Only thing the AT should change is shift timing. I dont see any issues running at normal shift times and I can always go into sport mode if i want to hit the higher RPMs.
Old May 5, 2014 | 06:07 PM
  #146
usdmJON's Avatar
I dont think the Endurance ILX was FI...
Old May 5, 2014 | 08:30 PM
  #147
Timmy18's Avatar
The AT should show less gains at the wheel across the band compared to a MT aside from down low thanks to the torque converter. I assumed these tests were Wheel power, and not a engine dyno.
All i know is the Honda AT in the Civic can handle a lot of power but I don't know how efficient it is/ how much is loss due to friction. The MT should have much less losses.
Old May 6, 2014 | 10:38 AM
  #148
usdmJON's Avatar
Point I'm making is why the need to point that out. Doesn't matter really. Thanks for the info hold the negativity.
Old May 6, 2014 | 06:36 PM
  #149
xdtownx's Avatar
Have you cut your bumper yet??
Old May 6, 2014 | 09:30 PM
  #150
OSUBeaver's Avatar
Nope not til the 23rd. Exhaust and downpipe going in the day before
Old May 6, 2014 | 09:35 PM
  #151
How do you like the progress 24mm sway bar? Big difference ?
Old May 6, 2014 | 11:14 PM
  #152
OSUBeaver's Avatar
Going in Friday. Just got it in the mail today
Old May 6, 2014 | 11:24 PM
  #153
Lemme know ! Im gunna buy it anyway but id like more opinions on the difference it made so I can decide when id end up buying it lol
Old May 7, 2014 | 01:15 PM
  #154
OSUBeaver's Avatar
Full Race 3" Downpipe. Won't be going in for a couple weeks. Exhaust is on a back order for 2 weeks or so.
Old May 7, 2014 | 02:00 PM
  #155
usdmJON's Avatar
Sweeet. I need a header so bad. That plus the DP I have would complete what youve got done there in one part.
Old May 7, 2014 | 03:41 PM
  #156
xdtownx's Avatar
I ordered my setup yesterday and they told me theres a 2 week wait for the exhaust too. When you do cut your bumper write the measurements down if you dont mind it would help me out a bunch. I have done all kinds of drafts on what size/shape I want to do but cant make a decision.
Old May 7, 2014 | 04:44 PM
  #157
OSUBeaver's Avatar
This bitch is twice as heavy as the downpipe! Maybe the guy at FKX Racing was right - he said the 24MM is too big for the ILX and will cause some rattling.
Old May 7, 2014 | 05:14 PM
  #158
usdmJON's Avatar
Looks great. I want to go around 19mm
Old May 8, 2014 | 06:23 PM
  #159
OSUBeaver's Avatar
Sorry for the Lack of Tire Shine - raining buckets here. F/R Rotors installed, Rear Tie Bar in and Progressive 24mm anti-sway bar in. Handles like a dream. Now just need the front tie bar
Old May 8, 2014 | 06:24 PM
  #160
OSUBeaver's Avatar
Putting in 25mm spacers in the rear tomorrow and moving the 19mm to the front
