Need help
Old Aug 20, 2020 | 04:05 PM
Tash123's Avatar
Need help
Hi I'm New to this,
I need help opening my Acura 2015 ilx the battery is completely dead. I bought a lockout kit to see if I can reach and open the car by unlocking it through that way but I'm not able to reach it because the tools given are too short. Also the key fob spare key is not opening the car door either. Does someone have any ideas on how to get into the car other then calling AAA or a locksmith.
Old Aug 20, 2020 | 04:40 PM
Call AAA, it's your best option without breaking something
Old Aug 23, 2020 | 03:41 PM
Paulcet's Avatar
6th Gear
Is the "key fob spare key" turning in the lock? If so, the key is fine. The rod that goes from the lock cylinder to the lock mechanism in the door is not connected. I just fixed this on my car yesterday, I should have taken some pics....
Old Aug 26, 2020 | 09:20 PM
Chrifff's Avatar
It is possible the key in the key fob is slightly bent (this happened to me once) you can correct it and use it to open the door. Or try using your second key set. Paulcet is correct, you should be able to open the door without power. Then get to your trunk release which is a cable (again not electric).
oHsicKtL
Sep 17, 2019 07:50 PM
nick5446
Nov 26, 2018 06:50 PM
Bluman
Nov 3, 2017 10:43 AM
Skeete32
Jul 11, 2009 06:32 PM
csmeance
Sep 13, 2008 10:36 PM
