Help with 2015 ILX mods
Old Jan 14, 2015 | 09:43 PM
evargas19's Avatar
8th Gear
I just purchased a 2015 ILX and I need help with my headlights and fog lights. I'm new to this and i want to change my headlights from regular to a blue looking bulb. And I want yellow fog lights. If you can please help me out on where I can get them that would be very helpful. Thank you! Also I would prefer quality bulbs. Price isn't really a problem because I used to own a BMW and i'm pretty sure parts are less expensive than a BMW.
Old Jan 14, 2015 | 10:26 PM
AcucaDude's Avatar
evargas19,
Congrats on the purchase!
Did you purchase a base model or a Premium/Tech Pkg? If you bought a base, the headlights are halogen and to get that "blue" look, you need to install a HID kit. I'm assuming you didn't since you have fog lights. If you bought a premium/tech pkg, it already has xenon HID headlights. The xenons give a white look with a hint of blue because of the projector. To get the blue look, you need to change the bulb, any D2S bulb at your wanted temperature should work.
For the fogs, you can choose yellow lamin-x to make it yellow or just get a HID kit and get 3k temperature.
Not sure where to get "quality" ones but I hope this clarified your question a bit.
Old Jan 15, 2015 | 12:38 AM
evargas19's Avatar
8th Gear
Originally Posted by AcucaDude
evargas19,
I just looked at it and yes I have a base model, so no fog lights. But do you know where I can buy this HID kit? Or do you recommend a place to look at?
Old Jan 15, 2015 | 09:32 AM
O-Dogg's Avatar
4th Gear
Ive used www.ledmodified.com in the past for HID's and still have a set I bought... About to install them in their second vehicle as the fog lights for my '14 2.4L this weekend... I will also be installing LED replacements (Yellow) for the day time running lights. Ill post pics next week.
Old Jan 15, 2015 | 09:35 AM
The Retrofit Source Inc
they are one of our vendors and if you use coupon code "ACURAZINE" you can get like 10% off
look into the Morimoto 3five HID kit !
ive been using this kit for 3 years now
Old Jan 15, 2015 | 09:57 AM
usdmJON's Avatar
Sounds to me like the OP is just interested in swapping out the bulbs not installing an entire kit.
OP.. are you willing to install an hid kit? Something with projectors? Just resistors? Or just bulbs?
Old Jan 15, 2015 | 10:41 AM
but you cant have an HID bulb without the ballast.
so, if the OP wants HID's, he'll need a kit that includes; Bulbs, ballast, and relay harness.
Old Jan 15, 2015 | 11:07 AM
evargas19's Avatar
8th Gear
If I have to buy the kit then I will buy the kit. As long as I get the lights how I want them, I'm fine with it. I just need help getting the right ones thats all
Old Jan 15, 2015 | 11:13 AM
your bulb type is H11.
here is the exact kit you need
http://www.theretrofitsource.com/hid...l#.VLf1H0RNots
Old Jan 15, 2015 | 11:14 AM
^im using this very exact kit on my '12 Kia Sportage
Old Jan 15, 2015 | 11:23 AM
evargas19's Avatar
8th Gear
Old Jan 15, 2015 | 11:59 AM
evargas19's Avatar
8th Gear
And which bulb will give the lights the more "blue" look?
Old Jan 15, 2015 | 12:20 PM
lets learn!
Science is a wonderful thing!!!!
light color is measured in a scale called Kelvin.
The higher you go up on the Kelvin scale, the more blue/purple you will see.
HOWEVER!!!!!!!!
the higher you go on the Kelvin Scale, the less visibility you have!
OEM manufactures use 4300k - 5000k for a reason!
because it throws the most usable light!!!
after about 6000 Kelvin, the bulb is blue but your visibility is LOST!
I would recommend you not go above 5000 Kelvin.
if you go above, YOU WILL HAVE A HARD TIME SEEING WHILE IT's RAINING.
that's science.
Old Jan 15, 2015 | 12:21 PM
usdmJON's Avatar
You will want bulbs labels as 5000k. 6000k will start to look REALLY blue almost purple at the edges in my opinion. I don't suggest going higher than 5000k. You can find them in the drop down menu under compatible h11 bulbs on the item justnspace posted for you.
I would 100% agree with Justin, that is the kit I would buy if I did not have an OEM HIDs.
As for fogs. You can contact your local dealership to get fogs installed or pick them up from any acuraparts website and have a local shop do the install. Your acura dealer would probably have the most straight forward solution and is your best bet if you dont mind paying a little more becausestealership.
Once you get the fogs you can either use yellow bulbs (cheap), amber LEDs with resistors (mid range), or more HID kit, this one will be tougher to install since there is no OEM option, then you can pick up the 3000k bulbs for a yellow tint.
I personally found the LED option to be great. I have amber LEDs with resistors right now for my fogs and LOVE them. They cost about 50$ on ebay for the LEDs and the resistors I bought in two different purchases.
usdmJON's Avatar
...what J-Space said.
Old Jan 15, 2015 | 12:22 PM
plus, you'll look like a stupid fucking ricer with blue bulbs
Old Jan 15, 2015 | 12:24 PM
the link I gave to the H11 HID kit even says this under technical details
  • Kelvin and Lumens (35W)
    3K Range:Golden Yellow (~2800 lm)
  • 4K Range:Warm White (~3100 lm)
  • 5K Range:Pure White (3000 lm)
  • 6K Range:Cool White (2900 lm)
  • XB55 50W Ballasts ( +20% intensity) (-20% lifespan)
*lumens is brightness.
as you can see 4000 K range has the highest Lumens.
Old Jan 15, 2015 | 12:53 PM
evargas19's Avatar
8th Gear
Okay now I'm getting a better understanding of this. And does the kit come with day time lights also?
Old Jan 15, 2015 | 01:06 PM
^no.
Old Jan 15, 2015 | 03:56 PM
evargas19's Avatar
8th Gear
^no.
So do I get the same kit for those too? Or is it a different kit?
Old Jan 15, 2015 | 06:37 PM
usdmJON's Avatar
Your day time running lights are in your high beams. You have asked to swap your low beams which run on their own with no day time lights. There is no kit that has day time lights in it.
aomechmarine's Avatar
What kit would you guys recommend for most brightness and yellow effect for the fogs? And that means it would have to be HID then? I know LED has come along nowadays.... I already have yellow Lamin-x covers, but want more yellow/yellow-ist and brighter/brightest possible setup. Willing to entertain a couple different ideas. Sell me on it.
Also isnt heat a possible issue with HID? and one setup or the other uses less energy right?
Old Jan 16, 2015 | 01:10 AM
lmend17's Avatar
I changed my fogs to a 3k yellow but I get a yellow/greenish look. I seen some other cars have that look as well. I don't know whats going on but eh just left if and said the hell with it.
Old Jan 16, 2015 | 02:33 AM
usdmJON's Avatar
Yes, 3000k will have a yellow hue with green around the edges.
Old Jan 16, 2015 | 10:45 AM
O-Dogg's Avatar
4th Gear
I will be installing Yellow LED's tomorrow for the Day-Time running lights, Ill post pics when done to give you an idea for what they look like.
Old Jan 17, 2015 | 12:56 AM
For the day time or fogs? I only want really yellow fogs for actual weather reasons - supposedly it does shine really well in fog. I've had really yellow fogs on my old car and it worked well in fog, increasing safety (at least thats what I felt).
Yellow Daytime running lights seems like it would be LOSING lumens, meaning losing visibility, meaning losing the purpose...
Am I wrong here?
If anything - shouldn't you be going in the other direction? Warm white? Post before and after for comparison.
tpraka300
3G MDX (2014-2020)
57
Dec 10, 2018 02:17 AM
space_boy
ILX
51
Aug 15, 2017 12:06 PM
corybgee
ILX
28
Oct 2, 2015 07:06 PM
jterp7
3G MDX (2014-2020)
Sep 21, 2015 11:02 AM
SpraykwoN
ILX
Sep 16, 2015 09:24 PM
