Dashcam hard wired help
Old Dec 20, 2019 | 08:49 PM
REEEEEEE's Avatar
Arrow Dashcam hard wired help
Hi! I tried to hardwire my dashcam but it doesn't turn on. I tapped into slot 39 which is the "premium audio" fuse of 20A with a fuse tap with a 5A fuse for the camera. I grounded the other wire but it won't turn on. anyone know any other fuse slots that work? Accessory fuse 19 can't be used and anyone that used it is at risk cause a fuse tap won't correctly fit with the + side
Old Dec 28, 2019 | 08:35 PM
csmeance's Avatar
Use a multimeter and check that you are getting 12V at the end of the fuse tap with 5A fuse. If not, the add a fuse is probably faulty or not crimped all the way. Most dashcams run on 3-5V and require a power adapter to change the 12V DC to 3-5V DC for the camera
garfield207
Sep 30, 2019 01:04 PM
KB1Spec
3G MDX (2014-2020)
Mar 2, 2017 12:51 AM
StormTrooperTL508
May 13, 2014 09:59 AM
zajac66
1G RDX Problems & Fixes
Feb 23, 2011 09:21 PM
em17henry
Aug 17, 2004 09:22 AM
