2015 with 2016 headlights? >>>>>>>
Old Sep 18, 2019 | 05:03 PM
REEEEEEE's Avatar
Arrow 2015 with 2016 headlights? >>>>>>>
2015 ILX with base headlights
would the 2016 full LED headlights fit ? anyone know or tried?
next question ! the radio screen on my 2015 is patetic and small. Anyone know a thread where they updated theres? I wana add the 2nd touch screen that replaces the middle buttons found on the 2016+ models but from what i see the 2015 also had it!
THANKS FOR THE HELP!!!!!!
Old Sep 19, 2019 | 09:17 AM
visi_d's Avatar
Headlights are different and cant say if they are mounted the same, but the bumper wont swap over so your out of luck. Also the radio swap is a no go. Should have bought the 2016 if you liked those features lol
Old Sep 19, 2019 | 07:43 PM
schen72's Avatar
No and no. The 2016-2018 headlights are a different shape so you'd have to get a new bumper and grill. If you price out these parts, it would probably be cheaper and easier to just sell your car and buy a 2016. Same goes for the 2016-2018 infotainment. Stop worrying about what newer models have. Chasing that stuff is a money pit. For example the 2019 has the next-gen Acura LED jewel eyes which look nicer.
It might be possible and reasonable to retrofit your base (halogen) headlights to HID, which I believe the higher trims had.
Old Sep 22, 2019 | 12:51 AM
REEEEEEE's Avatar
damn that sucks,.....
By the way i have the base model, is there a bigger screen i can install? does the nav models come witha bigger display? cause i feel its so small and the backup camera qauilty is worse than cheap ebay kits ive installed....
Old Sep 23, 2019 | 02:29 PM
schen72's Avatar
Yes, the models that have navi have a bigger screen. Again, there would be a lot to parts you'd have to retrofit. It is not worth it. However, if you have lots of money to throw down, anything can be done. I would personally just get a car that has what you want rather than try to mod a base trim.
Old Sep 23, 2019 | 06:48 PM
Thmanx's Avatar
FWIW: Someone on the RDX 2nd Gen forums did a 2016 Jewel eye install on his 2013 base RDX. Granted the bumper shape was the same around the headlights i think and it was doable. But he did create his own custom harness for the wiring and such.
And i think I did see some one (cant remember if it was on the forum or IG) who was able to get a lower LCD screen portion/radio unit from a 2016 ILX and install it in his 2015, it was like $150 used so it was worth a shot. Not sure if he ever got it wired up though. As for the top screen, not sure. I mean anything is doable with the right harness from a junked spare car.
Old Sep 27, 2019 | 10:51 AM
schen72's Avatar
That RDX retrofit looks nice! It's amazing how the jewel eye headlights really upgrade the look, not to mention the light output is amazing. Unfortunately, the headlight shape for ILX is different in 2016, so a new bumper is required. I think the grill size is different too, so then you're looking at a new hood? Sounds like $$$ to me. It's interesting how the 2nd gen RDX didn't change any body panels and simply changed lights. Definitely makes it easier for retrofitters.
Old Sep 29, 2019 | 10:17 PM
REEEEEEE's Avatar
yeah i gave up on the headlights but now i want to know if anyone knows if getting the 2013-2015 ilx nav screen < which is bigger right?> to replace the base screen which is too small for me!
also the back up camera is a potato 240p anyknow know if u can change the camera for a hd one ?
Old Sep 30, 2019 | 06:21 AM
DaIll1's Avatar
Sorry man, it sounds like you bought the wrong car. Does your likes outweigh the dislikes?
I got rid of my xb because the annoyances became overwhelming.
Old Oct 5, 2019 | 11:46 PM
schen72's Avatar
If you just replace the screen, I somehow doubt it's just going to work, as the bigger screen was used for the navi. so you also need to get the components for navi. Even the backup camera on the 2016+ is garbage. Low resolution. At least they add predictive lines, which helps when backing up into a space.
Old Oct 6, 2019 | 01:35 AM
also, agree...
if you wanted that stuff, you should have bought the car with that stuff to begin with..
Very hard to retrofit that stuff into a base car, without spending an arm and a leg.
Old Oct 6, 2019 | 10:22 PM
REEEEEEE's Avatar
:/ gave up on the radio and headlights hopefully an aftermarket version will be out when the car gets older but for now i swapped the 2015 for the 2016 tail lights and im gonna take my old subwoofer and install it in this car
Old Oct 7, 2019 | 03:40 PM
schen72's Avatar
Did you also wire up the part of the tail light that goes on the trunk lid?
Old Oct 7, 2019 | 03:41 PM
schen72's Avatar
Does the base 2015 ILX have projector headlamps? If so, maybe you can retrofit an LED bulb in there? Probably won't be as bright as the jewel eye headlights but could be an upgrade from halogen.
Old Oct 9, 2019 | 10:25 AM
^if it has projector head lights, his best bet would be to head over to Www.theretrofitsource.com to buy an HID kit..
aftermarket LED's arent anywhere close to being on the level of HID's.
the problem is; OP wants to keep things cheap..there's nothing cheap about buying the base car then trying to make it like the more equipped cars
Old Oct 9, 2019 | 11:40 AM
REEEEEEE's Avatar
^ Yea HID's beat LED in projector lenses.
Anywho, anyone selling parts? i need a 2016's ilx right side tail light none on ebay just 2 posts that are overpriced by some idiots
Old Oct 10, 2019 | 09:41 PM
DaIll1's Avatar
That's how marketing works, when not available, charge more.
Old May 22, 2025 | 06:09 PM
vick's Avatar
Hey what do I need to do to do the swap? I have 2014 Acura ilx
[QUOTE=Thmanx;16483534]FWIW: Someone on the RDX 2nd Gen forums did a 2016 Jewel eye install on his 2013 base RDX. Granted the bumper shape was the same around the headlights i think and it was doable. But he did create his own custom harness for the wiring and such.
ARich
Sep 10, 2019 06:17 AM
teopeht
Socal
15
Jul 15, 2009 11:38 AM
LiveFrom323
Sep 24, 2008 06:40 PM
