(2015) 2.4 Acura ILX on 20" rims lowered with D2 coilovers!!
#565
#566
It had gotten locked?
I forgot about that!
LEDS I normally buy from amazon or ledsource or something like that. It's been a while!
supercharger/turbo I have zero idea since my NA car is already much MUCH faster than any of those cars that have those.
#568
v-leds.com or theretrofitsource.com have good LED options, you just gotta go to here: http://www.sylvania.com/en-us/applic...s/lrgmain.aspx
to figure out bulb sizes, then go to whichever merchant you want to but the corresponding bulb.
I've heard good things about Diode Dynamics for LEDs as well. whalecum back
#569
#ledeeznuts #twankies #acura #ilx #stance #vip
I wouldn't go s/c.. custom turbo would be my route with piggyback controller and meth. Either route will be about 7-10k in parts and tuning. Several TSX guys are on chargers like ccccccolt, look through the TSX board.
#570
#571
Check out the recent poat thmanx made in my thread. Lots of great led links. I just did the reverse leds he suggested and they are great.
I will never buy cheap no name leds again.
Supercharger we have two. Talk yo osubeaver and slammedilx. Both of them have poated in their threads with their supercharger details.
#573
I got these new ones because thmanx really suggested them and he sounded very knowledgeable. Hes developing his own led line.
I compared them during the day and the new leds were bright enough to show on my garage door in day light. Old leds didnt show at all.
Next i will be buying his brake leds. The reverse leds are philips with 12 year warranties.
#575
Ragd. Here is the info Thmanx posted for me...
As for Fogs, there is absolutely no question; you want Philips.
They have a fantastic PnP LED system that runs at a constant 9W with no fan (it'll make any "80W Cree" bulb look like garbage by comparison, since those bulbs with all there LED's only run at 7-5W depending on heat/quality... and their optics are completely off for usability)
This amazon site has them for a serious steal ($135 vs $199 retail)
And their output is perfect
For DRL's
Again as much as the "80W style" claims to be the brightest, this is a false claim.
they get their numbers by multiplying the theoretical maximum wattage of each LED, times the number of LEDs on the unit. aka 5W Cree XB-D's X 16 (That and 99% of these bulbs do NOT use full Cree construction, often replacing them with equivalents from cheeper manufactures)
IF you want something that'll truly be useful as a DRL, you'll want my 9005 20W Homogeneous-LED. These like the Philips, are designed to work properly with your existing reflector.
Test on a 2008 Civic
As a test, I went out and bought the highest quality "80W Cree" bulb i could find, Diode-Dynamics, which use the latest 2.45mm XB-D's all the way around. And while it was the best 80W design I've seen, their output was a sham compared to my 20W design (since the light is actually being focused correctly)
See example below (IL4Spec was a name I as going to use from my previous employer before I went independent)
https://instagram.com/p/0zCCr6ypW2/ <-- video in action
Reverse Lights
The tricky thing is the small T10 size 921 bulbs used now as reverse lights simply don't have the punch the previous 1156's and 7440's had.
I've tried a "50W Cree" style 921 (2x front projector 8x on the sides) and all it does is flood the housing, not very useful.
The best ones i've seen are by Philips again.
Don't be confused by the single packaged Xtreme Visions as those are the international name, and sell for $25 each.
You want the 921 US variant (exact same wattage and color), as they sell for a pair @ the same price. 12 year life span and 3 year warranty; these are gold
License plates
Since our twin plate lights stick out and have a the license plate 90° from the bulb, You'll want a design that features flat COB boards to fire directly downward.
Morimoto have a design thats just that.
I've looked into bringing in a similar COB design myself, but the current designs i've seen are too long to fit. The Morimotos are the shortest COB board currently on the market & are a perfect fit in tight spaces.
Brake/Signal bulbs
Really depends on how much power you want.
If you want something that will light up your brake lights w/o blinding anyone to much.
the 744X based versions of my 20W design will get you there.
Ive tested them against the Philips Vision LED bulbs and their output is over 2X as bright (Philips intentionally did this, since they wanted their bulbs to be = to the original brightness. Though I've seen in some housings this results in about a 33% reduction in output vs a halogen.) My bulbs run at over double the wattage to compensate for any differences in housing shape or if you had smoked tails.
If you wanted something that would really set the world on fire. Look no further then my 30W Projector/Reflector Hybrids
Ive been testing these out on the HIDp forum for the last few months now, and the results are just electric. These stomp on everything i've seen to date as far as brightness and housing illumination as they incorporate both the highest quality 2.45mm Cree XB-D LEDs, as well as a proper design to utilize all that power correctly.
They are truly Mega
IL4Spec 30W Projector/Reflector Hybrid (2015 PreProduction) - YouTube
All these videos were done when the bulbs were still in their prototype stage, since my previous employer didn't believe in me when I told them they were some serious shit, I decided to bring my design and bulbs with me and go independent.
I'll be re-editing and changing the videos in the future to be posted on my own site.
For DRL's
Reverse Lights
License plates
Brake/Signal bulbs
They are truly Mega
#576
As for supercharger.
OSU is running a Comptech SC
https://acurazine.com/forums/acura-i...-903640/page7/
Aaron is running Kraftwerks
https://acurazine.com/forums/acura-i...-908440/page4/
As well, the 2013 ILX Endurance race car was running the same SC as OSU, the CT SC, but the new 2016 ILX Endurance race car is running a Rotrex SC by Jackson Racing.
#577
Wassup crew, so I got LEDs for my DRLs but i didnt want to connect the resistor or whatever that little gold square is called, i wanted plug and ay like the fog lights, reverse, tags....I connected my DRL directly to output and they are on, but not sure what issues this will create, so i need help....what are the gold squares for and do i really need them? And if i do how do i install them? Do i have to cut cables? Thats would be a non no for me.....
#578
Those resistors are designs to be plug and play. Are they just open wires or do the resistors each have a male and female plug?
It should have a male/female plug. You just attach the LED to one end of the resistor and the other into the car. Like an extension cord.
The point of a resisitor is to stop a couple things. One is hyper flashing. This is more often seen when replacing turn signals. The DRL does go from low to high beam so not sure what would happen there without resistors.
Second, a resistor will prevent a code from being thrown if the car doesnt detect the LED which is another often occurrence.
If neither of those issues are happening then I would assume you are fine to run them without resistors.
I have installed resistors with both my DRL and Fog upgrades. I would suggest the same as it isnt very hard. It's just like adding an extension cord to a light in your garage.
And what drls did you go with? Did you take thmanx advise?
#579
No i didnt get anything from that post, probably got chinese shit they came in a paperback with plastic and they say kelvin, now that you mention hyperflashing with the naked eye they are fine but when i see it through a camera lense or my phones camera then i can see them flashing, weird shit, yeah the resistors i was bei g offered only had two wires so i didntbget thay shit after i saw they worked, do u have a link where i could get them with the male and femaler adaptor for our car?
#580
Until then if you want to look it up just ebay search 9005 led resisitor. Theyll look like the pic i posted before. Probably around 20bucks for 2.
#581
Here ya go.
http://www.ebay.com/itm/9005-LED-DRL-Fog-Light-Canbus-50W-6Ohm-Load-Resistor-Wiring-Canceller-Decoder-/330940078458?hash=item4d0d90d97a&vxp=mtr
I clicked the first few. All seems to be shipping from cali for my search. But only 10 bucks for a pair and should be fast shipping still. I have these on my DRLs and fogs.
The flickering you see on your phone is not the same flickering these resistors stop. The flickering you see is only seen via recording electronics. My DRLs with resistors do the same thing when I try to take a pic of them.
The hyper flashing is in turn signals.
Disregard the music but that video with the scion shows hyper flashing verse a relay/resistor to fix it.
You shouldnt have that issue as you arent replacing turn signals.
The issue you could see is an error code the car may throw. I cant say exactly as I dont know the proper terminology but from my understanding LEDs have less current flowing through them which can trick the car into thinking the bulb is out or not even there. The resistor or relay will cancel that error code if you see one.
If you dont see any missing light error codes being thrown on your dash then you probably dont even need resistors. Mine came with the DRLs I bought so I have them. When I buy new DRLs from Thmanx I plan to plug them into the resistors since I already have them in.
You are probably fine without them if you dont see an error code on your dash.
#582
Here ya go.
9005 LED DRL Fog Light Canbus 50W 6ohm Load Resistor Wiring Canceller Decoder | eBay
LED Turn Signal Hyper Flashing Fix 2009 Scion xB - YouTube
#584
hahahaha that was a visual description of something I have no clue what its called, anyways I installed the "gold squares" and this shit did nothing, maybe they will extend the life of the led bulb, but that I will never know but I guess the drl can just be installed directly to the power supply with no problems
#586
I hope you mounted the gold squares to metal as they get SUPER HOT!
I installed LED switchback bulbs in my turn signals so they are white/blue when on but flash amber when you put the blinker on but I did not install the gold squares cuz I would have needed to take my bumper off but when I put my blinker on it flashes VERY fast compared to normal so thats why you need to install the gold squares lol.
I elected not to install mine FOR NOW cuz my car was JUST painted so I didnt wanna fuck around with fresh paint and my luck scratch something
#587
Lmao dude i told you you were probably fine without them.
They only have two purposes. To stop hyper flashing and a CEL or a maintenance reminder.
If you had neither then youre fine. Get led turn signals and you'll need the resistors there.
#588
LOL...who are you addressing Jon? Jeff is saying he got bad hyperflashing.
and @ the gold squares...you mean the resistors? I learned the hard way...those fkers get SUPER hot very very quickly...definitely put those on metal.
Jeff, for the TL...there's a thread on soldering a bypass on the lighting board to stop hyperflash without using individual resistors Mine has been going strong for YEARS.
https://acurazine.com/forums/third-g...istors-815219/
#589
#590
#591
Jon yes you did say i might not need them but for 10 bucks i just had to test it out, hahaha cant believe everything you read online, but thanks!
#599
Thanks! I wish I could get performance calipers instead of painting them but not worth it for this car so paint it is hehehe.
#600
It is ALWAYS worth it to ball Ragde. But I get that someone would rather put their money else where.
Any thoughts into being the first ILX with Weathertech visors? They released not too long ago and are 20 bucks cheaper than the HIC visors I got.
Just dont claim world first weathertech visors on an ILX. LMAO
