Setting Wireless name?
Old Dec 2, 2007 | 06:40 PM
sifuacura's Avatar
There's alot of asian in
Hey guys, I currently have 6 wireless router. 1 connects to the server while others are connected thru the ethernet slot of the 1st one.
Right now, i have the other 5 work as an access point by going into the router. I was wondering if I can change all of the name of the router to 1 name and 1 connection instead of having multiple names for each access point.
Some guy told me to disable the DHCP in the router that connect to the server..would that work?
Old Dec 3, 2007 | 01:47 AM
Whiskers's Avatar
Go Giants
My god...why 6 wifi routers?
Old Dec 3, 2007 | 08:42 AM
soopa's Avatar
The Creator
Maybe he has a 12,000 sq ft house?
Old Dec 3, 2007 | 09:02 AM
sifuacura's Avatar
business.
3 story building. 110 rooms
and im using the latest N1 wireless technology
Old Dec 3, 2007 | 09:05 AM
Whiskers's Avatar
Go Giants
Not sure why disabling DHCP would do anything. I think you can make them all the same name, but that won't help when going from one point to another since they have different SIDS...
Old Dec 3, 2007 | 10:05 PM
Billiam's Avatar
Big Block go VROOOM!
More questions: First, what wireless network client are you using on your machines, Windows built-in or one from the hardware vendor like Intel? The Windows wireless client is uber-stupid in environments that have multiple APs using the same SSID. It will always try to reconnect to the last AP it was connected to even if that one has a minuscule signal compared another closer AP. The only way to force the machine to connect to the strongest signal is to manually disable the radio then turn it back on.
Second, what are you using to restrict access, pre-shared keys, MAC filtering, 802.1x authentication? These things have the possibility of getting fickle when you start having multiple APs with the same SSID. To be fair though, a good number of these problems can be due to crappy management interfaces on the hardware that make it easy to mess up your own configs.
Old Dec 4, 2007 | 11:10 AM
sifuacura's Avatar
Your right, window is stupid when it comes to connecting to mutiple AP. When I was setting up the server, it keeps on connecting to the AP I don't want...very annoying. I'm using a pre-shared key for the security option. I'm using a company call Logix. I think creating multiple AP is better than 1 name because the people get option to choose the best signal don't you think? Or is 1 name less confusing for people? The SSID i assigned each one goes for certain room number...like Belkin N1 wireless goes to room 100-114. (i'm using the new N wireless techonology and its super great! with great amount of distant cover than my previous Belkin G Wireless Router.)
Biggie_B
May 27, 2025 05:51 PM
Jul 16, 2017 07:33 AM
gatrhumpy
19
Dec 31, 2015 04:22 PM
2ManyHobbies
Sep 24, 2015 09:23 PM
