New take on in-wall speakers
Anyone ever seen someone mount their surrounds in an opening in the wall.
Basically what I'd do is build a box into the wall (best example I could find below).
I would make an alcove the same size as the speaker and finish the outside with some picture frame moulding. Maybe even make a custom grill to fix over the opening. Basically it would be an in-wall speaker but removable. Probably insulate around the box in the wall to improve the sound.
This would be for all four surrounds + the center channel
Thoughts?
Thoughts?
Yeah haven't found a reasonably priced set of in-wall speakers that sound good.
My only question is acoustics.
I'm planning to push the speaker out as far as it will go (flush with the sheetrock).
Will probably line the alcove with this stuff
http://www.opentip.com/Electronics-C...p-1248051.html
Going to cover the opening with a grill like this.
Jim
This might help:
http://www.hometheatershack.com/foru...me-calculator/
I would think you would want option #1.
You can also read this:
http://www.kicker.com/building_enclosures
Thanks but the issue is these are already enclosed. They're the satellite speakers. I'm just curious (before I start cutting out sheetrock) what effect they will have if I recess them in the wall.
Can't seem to find much on the web.
I've thought of doing this, too. The only issue is if the speakers are ported, particularly rear ported. I don't believe the RC-Micro's are ported at all, though, so you should be fine (assuming you're still getting the Micro's).
I see no reason why this wouldn't work because like you said they are sealed. I have always wanted to sink my into the wall too because they are kinda ugly, especially the rear channels.
Hurry up and get pics
kb1rl
09-30-2015 10:17 AM
polish_pat
09-25-2015 12:24 PM
4drviper
09-23-2015 09:00 PM
rboller
09-23-2015 02:49 PM
