More watts than speakers can handle?
Unless your a bonehead you'll be fine, overpowering(with in reason) is better then underpowering. Most all consumer level electronics and speakers are very capable of working a little bit outside of there specified range with no ill effect.
I had a set of speakers that were rated from 2 watts to 200 watts and while I was waiting for a new amp to come in I was using an amp rated at 300 watts, conservatively rated. The speakers were VonSchweikert DB99 mkII's which are $15k speakers and the amps were Parasound JC-1 monoblocks, so it wasn't walmart shit with super exagerated power handling and output.
Nothing will happen. The difference is 10watts, hardly a difference.
Overpowering is better then underpowering. I was running a 250W/channel continuous pro amp through 6" bookshelf speakers for years without a problem.
I have an Onkyo receiver that is pushing 110 watts per channel. What happens if a get a speaker that is only rated at 100 watts power output?
This will make the music sound rich.
You always want an amp that is bigger than the speaker otherwise it will not sound good.
Originally Posted by Tireguy
As someone who has been into high end audio for over half of my life, I have never experienced a relationship between "rich sound" and using more power then the speakers recommend.
I just take his words for it...
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
