FM Antenna
Old Jul 12, 2007 | 11:29 AM
eve's Avatar
eve
FM Antenna
I bought one of those “all in one” home theater systems and the FM antenna that came with it is horrible. It’s basically a piece of wire that doesn’t do anything. I only get a couple of stations with minimal interference – everything else is not so good.
What kind of antenna should I get? Anything you recommend?
Old Jul 12, 2007 | 06:06 PM
2001AudiS4's Avatar
It really doesn't matter what you get. That antenna would work perfectly if it were placed somewhere where it could pick up signal. In fact, just today I hooked up an fm antenna that is that same style and everything was crystal clear. We had run a RG6 Coax cable out to the garage. That coax is plugged into the the receiver with a regular RG6 fitting (looks like a cable tv wire, same wire, same fitting) and then on the opposite side, put a fitting on the coax wire and barrelled (used a coupler) to the antenna and stapled it up high in the garage. It's about placement. I have even used a regular 16/2 speaker wire spliced onto the coax in place of the antenna. You are supposed to spread the two wires something like 31" apart from one another, or something like that. Anyway, if you can get a wire run to a higher location or outside the house, it would work fine.
Old Jul 16, 2007 | 11:56 AM
eve's Avatar
eve
I wish it was this easy. I live in a condo building, on the top floor (3rd) but my unit is surrounded by the building on both sides... think of a U shape building and I'm in the middle. I tried to move the wire closer to the window and higher up but nothing seems to work, I still get static. Maybe if I got a longer cable I could just hang it outside, haha. I have no idea what else to do...
oyayjoe
Jan 1, 2019 10:17 PM
us285126
Oct 2, 2015 02:03 PM
rhdune16
Sep 28, 2015 11:31 AM
vanderveen44
ILX
Sep 16, 2015 10:51 AM
oyayjoe
Sep 12, 2015 04:40 PM
