Cable length
Old Nov 16, 2006 | 09:40 AM
TBone2004's Avatar
Team Anthracite Member
Cable length
I am getting a new cable for my subwoofer - since I had to relocate it in the new house. The current one is now too short.
Does it degrade the sound or anything if I buy it a little longer than needed - or should I get the length that is as close to exact fit as possible? It comes in an 18ft and 24ft length. The width of the room is 15ft + the distance from the floor up to back of the receiver (3ft?) - kinda close with an 18ft I think. Any harm going with the 24ft?
Also, Is it bad to have the sub near the sofa instead of up near the front by the TV? I thought I read it was supposed to be near the TV (front of room). I just do not have the space to do that.
Thanks!
Old Nov 16, 2006 | 10:45 AM
IlliNorge's Avatar
Benchwarmer
An extra 6 feet will have no effect. I doubt an extra 60 feet would have any effect on low frequencies. As for the sub, bass is pretty much omni-directional. You would probably feel it vibrating your couch before you would "hear" that it's by your couch.
Old Nov 16, 2006 | 04:33 PM
phipark's Avatar
Not Asian
Get the 24 footer. You'll be amazed how much extra you may need with routing the cable.
Old Nov 16, 2006 | 04:34 PM
DanUC's Avatar
I was under the impression the only problem you have with different cord lenghts is that it takes each speaker is getting the signal at different times. But how significant that is when you are talking a couple feet I don't know.
I might be way off on that though
Old Nov 17, 2006 | 07:30 AM
TBone2004's Avatar
yo good call! I bought the 24' and sure enough only really had about a foot or two left over!! It did kinda get sucked up along the way.
Thanks guys.
Old Nov 17, 2006 | 11:41 AM
phipark's Avatar
Not Asian
Well, if you have a high end receiver, you can actually adjust the distances of the speakers through an on-screen menu.
Old Nov 17, 2006 | 01:59 PM
soopa's Avatar
The Creator
my cable run to my subwoofer is something like 3 wires and 32-38 ft (receiver to wall, wall to wall, wall to sub). you'll be fine.
Old Nov 17, 2006 | 02:13 PM
fdl's Avatar
fdl
Strictly speaking, you want to limit cable lengths, and also match left and right lengths, etc.
But realistically, if you can notice a diff in sound due to an extra 6 feet of cable, you've got one hell of a set of ears.
Old Nov 17, 2006 | 02:30 PM
fuzzy02CLS's Avatar
I once had 2 50 foot RCA's coupled together that ran a sub. Worked & sounded just fine to me.
Old Nov 17, 2006 | 02:45 PM
jlukja's Avatar
You don't want to coil speaker wire because you'll introduce inductance into the circuit.
cycdaniel
Dec 17, 2019 10:58 AM
lanechanger
Oct 13, 2015 10:56 AM
ValdezQ26
Oct 1, 2015 04:48 PM
jmaxima03
Sep 27, 2015 10:22 AM
tndirtdauber
Sep 23, 2015 03:00 PM
