65" 4K OLED vs. 75" 4K LED?
Thoughts on this decision? Also any good deals you know of feel free to share. Black Friday? Etc.
I am leaning towards the OLED right now just from seeing the picture quality and blacks, but was curious on your thoughts - are there any 75" LED's that rival the OLED experience? Even sort of close would be curious.
I've been putting off this purchase forever, I think it's time.
I think there are two basic strategies:
1.) Buy the newest thing, spending as much as you can afford, possibly compromising something (screen size here, most likely), or
2.) Value shop, basically buying 'last years model' with all the features you want.
#1 kind of 'future proofs' you .... not really, but your tech will be newer longer. #2 you might get more 'stuff' but the tech is already on the way out.
In either case, you've probably got something that will last a couple of generations.
I work on TV's for a living, so I'll have a different take.
Avoid LED if possible. Most of the problems we have today are due to poor design with LED backlight. The full array are most troublesome, but still have issues with the edge lit. The average age these sets come to visit me, less than 3 years old. If you must get LED backlit, keep the brightness or backlight settings as low as possible to still see a good image, but don't run it maxed out. The problems are simply due to manufacturers cutting costs. They overdrive the led's to give a bright, vibrant screen initially, but seriously cut the overall lifespan of the arrays by using underrated LED's.
If you can, I would recommend the OLED over LED. But they have drawbacks also. They are similar (not really, but for comparison sake) to plasma. With the same possibility of burn in. They all have different compensation intervals to help balance the panels. But if you really likeshows with static banners, manually run compensation a little more frequently. What ever you do, don't leave it on a program to entertain your pets, get a radio. Manufacturers do not consider screen burn a warranty issue. I was out on one last week that was left on FOX news for the dog. When I went into the all white test patterns, the FOX news banner was clearly burned in.
And lastly avoid black friday sales like the plague. Many name brand sets, are built with hold over parts, to just clear out the warehouses. If its a model that you've seen around throughout the year, and just marked down then, that should be ok. But if it isn't a model you've seen before, run. I tend to get a 30% jump right after black friday on warranty calls for new sets. I call in to the manufacturers, and I get the same comment everytime, ohhhhhh a black friday model. If its not a major brand, run at anytime, no matter the price.
Thanks buds - great info - that is the kind of direction I was looking for. OLED has def been on my mind, I just wanted some more opinions.
And being a photography person I definitely know about the "next model" conundrum / challenge. Hell just last month I bought a camera and the next model was announced 2 days later - after reviewing the differences I found it to be a worthy upgrade and returned the old model and got the new one. The struggle is real.
The Sony A1 does have an app to remove the burn-ins, but I don't know too much detail about it.
And that post about the weaknesses of the current TVs is excellent, unfortunately I have already bought a full array TV so hopefully I don't have to deal with the problems within 3 years.
It may help, but not recommended. Compensation, or balancing is done when the panel is mostly off. I haven't investigated the theory behind compensation, and what its actually doing. But it differs from the "wiping" that you did with the older plasmas. Running a white screen is actually degrading the whole panel equally. All panels degrade over time (even lcd/led). Burn in, is when one section is degraded a little more than another. The major difference, when an OLED gets far enough out of balance, it won't power the panel any longer.
If I have time over the next couple weeks, I'll read between the lines in some of the service literature out on the various OLEDs. But between a complete change over of the audio system in our TL,,,,and all the LED panels I'm rebuilding, not a lot of free time. LOL
The durability of an LCD produced in 2010, and the LEDs produced today, is dramatic. Personally, if something happened to a 2010 set, I would fix that (within reason), before buying a new one. All but one of the TV's I use, and what my daughter and her family have, are older than that......and I keep those running for a reason.
Stranger Things Season 2 now streaming in 4k with HDR
OK. I think it's time.
Good luck!!! Make sure to get an extended warranty. And look at the contract for that warranty. Some warranties are claiming 5 years p&l,,,,,but the fine print states that you have to ship the set to another location at your expense. I don't have any more insight other than that on the companies. I've cut all ties with extended plans.
Not yet.
I am waiting on a LG 65" OLED price to come down
Sources saying coming down significantly soon. So.
Personally, I'd go size over picture quality.
about 7 years ago, I spent a small fortune on a nice Samsung tv.. I think it was 56" in size. I could've gone for a bigger, lower quality image screen, or the smaller, higher quality image. Well, that TV is old as balls now, and even the most average tv boasts image quality at that Samsung level... but I sure as hell cant make the old screen any bigger.
turth be told, unless these TVs are side by side, I have a very hard time identififying the better picture. I honestly don't see the value in spending money on super expensive picture quality that will be surpassed and obsolete in no time. As for size? 75" will always be 75".
I just bought a new 70" tv last week, and followed the same ideology. So far, no regrets. Average TV that has better picture quality than my much more expensive and older Samsung. TVs are disposable tech these days. If it shits the bed, zero fucks given. Yeah, I'd care if I paid 4-5k for the tv. But at 1350... meh. If it lasts two years, that's money well spent.
I bought a 65" LG OLED C7P... I don't think I can go back now... the picture on this TV is insane, I love it, most of the content I watch now is HDR or Dolby Vision... holy shit its beautiful.
DON'T TOUCH THAT FUCKING SITE. There are many BS sites that once you give your credit card info they will begin to fuck you over. They'll call you and give you the runaround on how they don't have the TV or some other BS. Just use them for a price match with your credit card.
Just picked up a Series 8 Samsung 65" 4k last week.
For one, it's a massive upgrade over the 8 year old 42" Samsung we had before, which is still working great & being moved into our room.
The only thing I've noticed so far, is a bit of picture jerkiness on local channels. There's absolutely no jerkiness on cable or premium channels. Streaming Amazon Video or Netflix
amazing.
Have equipment coming in today to wall mount it.
amazing.Have equipment coming in today to wall mount it.
amazing.
Was hoping to mount mine tonight, but the hardware didn't come in from Amazon
Part of the order was delivered by UPS, the mounts are being delivered by Amazon & will probably come in tomorrow.
oh dang, you went with the 8 series too, eh? Man, I don't even want to know the price tag of that TV in 82"
Seems like a solid choice though- good picture and ginormous size. As long as it doesn't die prematurely, I bet that thing will be in your living room for a very long time.
Give yourself some credit on that front. The more I thought about it and prioritized my "wants" in a TV the more I realized I wanted as much of a "cinema" type of experience as I could get, within reason (i.e. not the high end). And, while 75" would have been "enough", even years ago I envisioned myself getting a 80+ down the road. So here we are. I weighed the cost factors over and over again, and finally decided, given the last TV I bought was in 2009, that I'm ok with putting some extra in for the larger set. will do
