$1,000 off of Panasonic 50" HD Plasma
mushroom mushroom
Panasonic TH-50PH9UK Black 50" 16:9 Professional Series HD Plasma
$900 instant savings and $100 mail in rebate
http://www.newegg.com/product/produc...82E16889187012
also
Panasonic TH-42PH9UK Black 42" 16:9 Professional Series HD Plasma
$700 instant savings
http://www.newegg.com/product/produc...82E16889187013
enjoy! I'll be ording the 50" tomorrow and maybe the 42" for the bedroom.
also
The Creator
Originally Posted by fuzzy02CLS
That's only a monitor though, no tuner.
Originally Posted by soopa
I haven't used the built-in tuner of any of my televisions in at least 6 years. between tivo's and cable boxes... who needs it.
That is a pretty good deal.
The sizzle in the Steak
CNET editors' review
Excellent
8.0
out of 10The good: Relatively inexpensive; excellent black-level performance; accurate color decoding; solid video processing with 2:3 pull-down; independent memory per input; versatile PIP function; extensive picture adjustments; customizable inputs.
The bad: Inaccurate primary colors; does not include a stand, a tuner, or speakers; limited to only four total inputs and doesn't include a digital input out of the box; cannot change aspect ratios with HDTV sources.
The bottom line: Although its features can't compete against typical consumer plasmas, the "professional" Panasonic TH-50PH9UK's excellent picture quality and price make it the best value at this size, bar none.
Excellent
8.0
I think you guys are missing the point of fuzzy's post.
It really is just a monitor.
It has no co-ax connection, no HDMI or DVI input, no built-in speakers, nothing. So if you want to use it as a TV you'll need a cable box or sat box and you can hook it up via component. Or you can buy add-on "slots" which allows you to add inputs. So you could buy an HDMI "slot", install it into the back of the set, then you'll have HDMI connectivity.
And, on top of all of that, you need to buy some kind of audio system since there are no speakers built-in.
So be prepared to spend several hundred dollars more just to make it watchable. It's still a good deal b/c of the quality of the set... but it is far from a plug and play set.
I also don't understand how they can advertise 1080p support when the native resolution of the set is 1366 x 768, also known as 720p.
Me thinks it cannot support 1080p and that is a mis-print. I'm also not able to pull up that TV on Panasonic's website to verify.
Still, it's a good deal, but the odds are it's a 720p set and like I said above, it's not plug and play as a TV...
For anything you stick on the wall, monitor > TV imho. I love the clean look of it on the wall with no speakers. What's the point of having a nice display if you don't have the sound system to back it up? If I needed another one I would get that Panny and whatever board I need for HDMI in a heartbeat.
Also, the Panny monitor probably does accept 1080p input but will output 720p. My NEC monitor will accept 1080p on component only, not HDMI. All output is 720p. Now I sort of wished I waited a year, what a price drop. Oh well, no matter when you buy it will be cheaper in 6 months I guess.
Received 1,080 Likes
Better deal on that TV + you can still use the $100 rebate
http://www.tvauthority.com/Plasma-TV...K.asp?aff=5183
And agreed... but I think there's a misconception about this TV based on the way I was reading the few replies above. And there are exceptions where a plasma with speakers is desired. Example, our plasma is in our bedroom. I have no need for a sound system in there. So that's where people need to be careful, b/c if they intend to put this monitor in a location like that, you can't just buy it and use it. You DO need a tuner and you DO need an audio system to watch TV. Otherwise, yes, I agree, if this is your main TV, then you should have a sweet sound system to back it up.
Still makes no sense about the 1080p though. Since every device that outputs in 1080p also outputs in 720p and 1080i, it makes no sense for them to even list 1080p if it can't be displayed. If you had your BluRay set to output to 1080p only, odds are that TV would not be able to display it. So it's very misleading b/c in reality, it's only a 720p set...
mushroom mushroom
Here is a review with a video that explains alot about this plasma.
http://reviews.cnet.com/Panasonic_TH...-31986328.html
This plasma is a monitor right out of the box. But like bean said it has expansion slot where you can change the imputs. I like the versatillity of this because when new technologies come out it makes this plasma kind of future proof. I also like the ability to tune the picture more than the consumer models.
They have all kinds of card including HDMI.
here is a list of all the imputs blades available:
http://catalog2.panasonic.com/webapp...K&displayTab=S
here is the link to panasonic:
http://catalog2.panasonic.com/webapp...del=TH-50PH9UK
I dunno about cards actually future proofing a monitor. Say your monitor is 5 years old and some new fancy connector comes out. What's the chance of cards that the current year's monitor accept actually working in yours?
edit - That article lists the HDMI adapter as $110. TV Authority had it for $149. Still add that in, plus a wall mount or stand ($150-$300), plus renting or purchasing a cable or sat box, plus an audio system, and you can get a true idea of the cost of this thing. If this were to be purchased as a main TV or a Home Theater display, it's perfect... but for "standard" consumer use, you're probably better off going to an electronics store for a more "plug & play" plasma...
But that damn 42" version is soooooo tempting
mushroom mushroom
If you subsribe to a cable or sat. service the box takes the place of the built in tuner.
Well, duh, I know that. But this set does NOT have a built-in tuner, hence the reason you MUST have a cable or sat box in order to use it as THIS set as a TV.
But yes, normally if a TV has a built-in tuner you don't need a STB and if you have one, it replaces the tuner. But, as mentioned several times, that is not the case here as was indicated in that reply (and if you leave that sentence in the context it was used).
mushroom mushroom
Whoops that was supposed to be a question and not a statement. But you answered my question anyways.
Sorry I'm still in the learning process...the AVS forums have helped me a lot!
This is the kind of TV (Monitor) that I picture at the airport displaying flight information. For me, it's not my style. I like features included with my TV. 50" wouldn't be big enough for my home theatre and a lack of features makes it impractical as a bedroom TV.
mushroom mushroom
http://catalog2.panasonic.com/webapp...el=TH-103PF9UK
mushroom mushroom
OK I just placed my order...too bad I have to wait until we close on the new place to install the display. Damn builder is dragging their feet our original COE date was two month ago and now we are looking at mid December. Oh well at least I can stare at a 50" cardboard box till then.
^ Nice!
Did you go with the stand or buy the wall mount?
Any thoughts to the audio system, or are you going to wait on that until you move in? I've been seriously toying with this for the bonus room since that room has surround sound built in, and I already have the receiver there. The wife doesn't like the idea though, she wants to get a 60" for downstairs and move the 50" DLP up to the bonus room which was our original plan. But that is a sick deal. Oh well...
mushroom mushroom
^ Nice!
As for the audio, this display will be going into the living room pre-wired for 5.1. Right now I have some nice PSB in-room speakers but I think I’m going put those up in the loft and to go with an in-wall system. I have a decent receiver but it’s a few years old and I’m considering an upgrade. As you can see I haven’t put much consideration into the audio but I’ve got time. Do you have any suggestions?
Big Block go VROOOM!
Two additional points on these Panny's:
1) With the connector blade slots, you could configure these monitors with two HDMI inputs. Something that (the last time I checked) is still difficult to find on 42" and 50" consumer plasmas.
2) Panasonic offers (overpriced) add-on speakers for these guys so I would think there has to be some basic audio capability and an output of some sort. Assuming they don't use any sort of bastard connector, you can probably attach whatever pair of powered speakers you'd like to these guys. Further research is necessary of course.
As of right now this is kind of what I had in mind. One of my architect friends has a laser cutting machine in his studio and he is going to create a clear plastic custom bracket for mounting the plasma on the wall. I intend to stick all of the components in a nearby closet and control every thing off of IR sensors.
I'm using a Pioneer receiver now on both setups. It's about a year old at this point, but it still kicks. Only thing that sucks is that it doesn't have HDMI connectivity, but so far I've been OK just using digital audio connections and the HDMI for video only.
Almost all Monitors have audio outputs in the form of normal speaker terminals. You can but in wall speakers or just about anything speaker if you really wish and just connect them directly to the tv if you do not wish to go the full surround sound route.
Bug 230- I suggest you check you the Marantz receivers. You could get buy with the SR4001 or SR5001 (if you desire multi-zone functionality). Both are capable receivers. If you are willing to spend a little extra, then check out th SR7001 or SR8001. Both are THX certified and have I believe 4 HDMI inputs and at least one out (the SR8001 has two HDMI outputs). They both also have 4 Component inputs and 2 outputs. They sound incredible and are very well built. You will love any of these receivers if you get one.
I wonder if the stand for the consumer line fits the pro series. I have a stand in my basement new in the box that a customer didn't want. I'll have to see if it fits. I'd sell it for maybe $50 shipped if it fits. I doubt it will though. Its a different design.
mushroom mushroom
almost pulled the trigger on this but i gotta wait....just went over to avsforum haven't been there since last year...there's too much going on (prices, new sets, deals, christmas) to simply buy this panny monitor. how's it going to look with tivo hd, ps3?
Everyday Joe
^^^^Just about to do the same thing. I've got a 10K that I can use on some house things and I'm thinking a nice HD big screen for the master BR would be fantastic....
Pham Alvan
03-16-2016 09:17 AM
