Solar LED Walk Lights
Has anyone purchased Solar LED Walk Lights for their back/front yards? I'm looking to add some to my new backyard so I can see the dogs late at night. Looking to get something like this..
6 for $25 isn't bad IMO and the backyard gets a lot of light for them to charge.
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
I've been looking at these, but I don't like the cheap plastic ones that HD has for sale, I've been looking at the metal ones that are a bit more expensive, sam's has a set of metalic (at least looking) ones for $50 for a set and they look more sturdy. I just don't like the $17-25 ones because they seem so cheap
Solar lights are worthless.
The emit light, but do not illuminate an area.
Christmas lights would provide you the same if not better illumination.
Get yourself some low voltage lighting, you will be much happier.
I just got the six pack of them from Home Depot for $18. They're not that great, but for $3 a piece you really can't expect much. They really don't illuminate much, but I just got them for decoration anyway. If you're looking to actually illuminate something, you'd be better off with some form of corded lighting.
They look cheesy, they emit less light than a firefly, and the temperature of the light is terrible.
Everything about them screams cheap afterthought crap.
Low voltage lighting or real landscape lighting FTW.
These appear to be higher end solar lights but I can't speak for how well they work. I was just curious to see what was out there and found them.
http://www.gardeners.com/Solar-Light...efault,sc.html
^^ No offense, but my mom purchased those off of QVC....they are the same as all the rest...bad temp. light color, and no illumination.
She claimed when she watched on QVC they were supposed to be the best solar around...lots of light....now a few months later, she knows they are meh....and what's worse is the solar panel on top is getting "dull" and it appears this is resulting in even less light output.
I have the $4 ones from HD, and I use them as decoration. I don't expect them to actually light anything, so I'm happy. However, I do have about eight of them surrounding the back yard, and they do illuminate a fair amount of my back yard.
I also think you should get a low-voltage lighting system for accent lights. They really help and they look great over a bottle of wine!
I bought some to just "illuminate" the landscaped area i have as a temporary solution till i finish the landscaping and put low voltage lights in. Solar lights are garbage. Mine are bright white LED and hardly "illuminate" is about all they do. If any one of them dont receive sun they wont light up, if its a cloudy day or 2 they dont charge and wont light up. Spend the money on low voltage lights. You will thank yourself. I will most likely replace the ones i put in with low voltage even though im not finished with the landscaping.
Alternatively, if you're doing it ONLY to see where your dog is at night, you could forget the lights and illuminate your dog instead. We have a light-up collar and a long light-up tag that hangs from his collar that we use to see our dog at night when we're in the country. We just make the night collar larger than it needs to be and throw it on so it fits over his other collar. Our light-up tag looks like the first image but has a D-ring to allow it to hang from his collar -- it isn't actually a collar cover like shown below.
This
This
Or only one of them will do you just fine to see where your dog is, although you'll only see the collar and not what your dog is actually up to. Both are $5-$10.
This
This
^Pretty good idea on the collar, but when my dogs are home I don't leave collars on them.. Don't know why, but I just prefer them without collars.
That leads to the problem of whenever I go to put a collar on them they KNOW they are leaving the house and go crazy! Don't think putting one on at night would be worth it
I will look into the low voltage lighting.
My parents have some in the backyard that are pretty good. Not just a cheapo set. They use them to illuminate the two walkways (no grass just landscaping) and path connecting the two that go from the exterior patios to the pool deck. They work great for that application. I would not however suggest them (even a 'nicer' set) for illuminating larger areas.
They're great for pathways/small areas, but otherwise I'd suggest some other form of lighting.
Could be the camera, but those are very dim compared to ours which really put out a lot of light. I don't even have to turn on any lights outside to see where I am walking, etc.
rockyboy
08-04-2024 10:35 AM
Greengecko
09-16-2015 08:19 PM
oyayjoe
09-12-2015 04:40 PM
drewdeezy03
09-03-2015 08:04 PM
