Recessed Lighting
I did this - it was real easy to do. I got the kind that can come in contact with isulation. I was able to install them on my first floor ceiling without access from above floor. They looked great and worked great. P.S> I am no master electrician either. IMO no class necessary.
Well, I only did two (replaced a nasty flourescent light in kitchen with two recessed lights). Ummm...well, may depend on code, as far as what kind of wire protection you need. I was lucky my two lights were in the same joist cavity. If they were not - my particular joists were those kind that were assembled 2x4's so the wire could easily have passed through to the next one. Else I would drill a hole
I want to install some of the smaller recessed lamps into the baby's room at our place. There is a switch on the wall for one of the outlets so we can operate a lamp. I'm not the best at this electrical crap either, so is it usually easy to use that switch to operate those recessed lights instead or will I have to install another switch?
- might as well put the dimmer switch on now for when your child wants the light on and the nightlight was making shadows
Originally Posted by Scottman111
Mach30, how many joists do you have to go through? And how far apart are the lights going to be?
I do not have access to the attic - this is in a condo so i doubt the neightbors would let me rip up there carpet and cut a hole in the floor.
The lights are going to be 7-8 feet apart. Its a rectangle room and i want to put 4 lights in. sorta one in each corner.
There is already a cieling fan up ther that i'm sure i can tap into for power?!?? i think.
With a distance that far apart it's gonna be difficult. Problem is getting electricity to each light, since you can't get up in the ceiling.
I can't say that it's code but I've seen people cut notches out of the drywall just below each ceiling joist and fish the wire up into the ceiling and when you get to the joist, use a Romex staple to hold it in place. Then you need to tape the notch using fiberglass mesh and then spackle over it. It might not look that pretty though when you're done.
why can't you just drill a small hole through each joist? That is how it is done in new construction, what is the difference? Maybe I am not understanding the issue. (other than the larger hole(s) needed to get your drill up there)
And yes, I would use that power supply from the previous light - that is what I did.
There isn't an issue, just wondering if theres an easier way then ripping the cieling up every 18 inches to drill the hole. I think this is what i might have to do, because i'm worried about drilling blindly though a joist and acciently hitting wires or the sprinkler system
Hey I did same thing - I installed another switch - made existing switchbox a double - they make great remodeling boxes so you do not have to worry about nailing into a stud etc.
Can someone post a picture for me? I drew something up for him but I can't access my photo host site from work.
Give me an email address and I'll send you the jpeg to host.
Buy a Greenlee flex bit:
-Get a 36" flew bit
-Cut a holes in the ceiling where you want the can lights
-Feed the bit in to the ceiling thru oen of the holes
-Drill thru the joists from one hole to the other
-Do not remove the drill bit - instead, attach the electrical wire to the end of the flex bit
-Pull the bit back thru the hole and the electric cable comes with it
I've done this many times with coax cable. If I can do it so can you
-Get a 36" flew bit
mada51589
Jan 9, 2025 04:40 PM
sockr1
Oct 1, 2015 01:31 AM
wusty23jd
Sep 24, 2015 11:41 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
