OK DYI'ers..
Old May 23, 2011 | 02:52 PM
HondaCrazy's Avatar
OK DYI'ers..
Anyone ever bend thin gauge aluminum without a brake? I have a need to wrap aluminum around a 7' L 4x4, and 2 4' L 2x6's. I have called a few contractors, no one wants to help with such a small project. I was thinking of making my own out of a sheet of plywood and a 2x4.
Problem is, I would like it to look nice as it is being installed on my back porch.
Ideas?
Old May 23, 2011 | 03:08 PM
CocheseUGA's Avatar
Ideas?
Two problems I can see with your idea:
1) 2x4s are slightly rounded. So if you're looking for a clean 90 degree bend, you aren't going to get it without using a sharp edge.
2) I think to get your bend right you have to go slightly past 90 degrees.
I'd check out a HF to see if any of these would work: http://www.harborfreight.com/catalog...?q=metal+brake
Or use a metal edge on your project.
Old May 23, 2011 | 03:11 PM
AMUA6's Avatar
ScoobyZINE
I would find some one to let you use a brake IMO.. I went down the same road building my oven and ended up using a friend's buddy's dad's whoever's brake after getting all of my measurements first.
Old May 23, 2011 | 03:30 PM
stogie1020's Avatar
Needs more Lemon Pledge
Does it have to wrap continuously? What I mean is could you do two sides of the post with one piece and then the other two sides with another piece?
Reason I ask is you can buy pre-bent aluminum flashing for roofing, chimneys, etc... but it is a single bend so you get a "L" not a four sided box.
Old May 24, 2011 | 11:55 AM
fsttyms1's Avatar
Check your local rental stores. I know the one down the street from me has one to rent.
e30cabrio
May 11, 2009 09:25 AM
Zasker1
Mar 18, 2009 12:11 AM
perlztt
Feb 23, 2009 07:05 PM
daNNiebOixDD
Sep 20, 2006 07:51 PM
sexytypes
Nov 17, 2005 02:04 PM
