Laying HW: Along the length of room, or parallel to the light?
I have a 24 x16 room I am doing in HW.
Trying to decide how to orient the planks. I have heard its best to lay them along the long side of the room. But, I've also heard its best to lay them parallel to the light entering the room, which is this case is across the width.
Which way is best?
Which way is best?
more Q's
missed the edit...
More questions. The boxes of HW I have do not come with any install instructions. Nor is there any mfr name.
I want to staple it to a wood sub floor, but don't know what size staples to use. Is there a way to figure this out?
It's engineered HW, for below grade install.
Planks are 5" wide:
By 1/2" thick, with the tongue being 1/8 thick ("A") with 3/16 either side:
Planks are 5" wide:
FWIW, I called the installer for advice on stapling. Coincidentally, he was installing the same brand of floor on site and recommended that I glue the joins, and not bother stapling.
re
is that hardwood or engineered wood? If its HW u gotta install it perpendicular to th floor joist or your floor will constantly have cracking noises and wont be very solid, but if its engineered wood which is glued down you can go whichever direction you like.
Go fancy on a 45 degree floor hehe
put up some pics
put up some pics
It's engineered HW (for belwo grade). No joists, just going on a subfloor, over concrete.
45 looks good on decks, but I've never seen it done in HW. Saw a herringbone HW floor; it looked great, but there must have been a lot of wasted wood.
