How to Remove Tumbled Marble Backsplash?
Old 08-03-2013, 02:01 PM
Making it Happen
Renegade's Avatar
How do I remove tumbled marble backsplash in my kitchen? It appears that the marble itself on the sides is filled with grout, but not sure what the person used to have it glued to the drywall. I put a putty knife behind and tried to push it off but it wasnt working well. Any advice?
Old 08-06-2013, 04:28 PM
The sizzle in the Steak
Moog-Type-S's Avatar
Received 1,877 Likes on 1,297 Posts
It's not much different than any other tile back splash removal.
Instructions
Use your grout remover to file away the grout around a single tile. File as deep as you can. You can also use a rotary tool, such as a Dremmel, or a drill with a grout removing bit. Wear safety glasses and a dust mask when removing grout manually or with power tools.
Use your ceramic chisel and hammer to chisel a crack into the center of the tile. Then chisel the pieces away so that you can reach the edges of the other tiles.
Use your small, flat crowbar or spackling knife to reach between the tile and the drywall. Hammer it into the space behind the tile, creating a gap between it and the drywall. With luck, the tile will come off easily and in one piece.
Continue to use the crowbar and hammer until all the desired tiles are removed. If the drywall is still intact, then this is good. If not, the drywall surface must be patched or replaced, especially if there's water damage.
Use your spackling knife to scrape away the old adhesive. Use the spackling knife to also mix a little plaster of Paris into the joint compound, and then patch and smooth any minor indentations or holes. Let dry.
Sand smooth the scraped, patched and dried wall. You can either paint it or put new tile on the wall.
http://www.ehow.com/how_4869098_remo...#ixzz2bE7h7nLk
Read more: http://www.ehow.com/how_4869098_remo...#ixzz2bE7czt00
97BlackAckCL (08-07-2013)
Old 08-06-2013, 05:09 PM
Making it Happen
Renegade's Avatar
Thanks, I got most of it off except for one part where I ripped the hole drywall out in about a 24"x24" space!!! So I need to replace the drywall there, but everywhere else came out well
Old 08-06-2013, 06:04 PM
Good show!
Old 08-08-2013, 07:50 AM
KaMLuNg's Avatar
Received 1,090 Likes on 767 Posts
sledge hammer and crow bar always works well when removing tile...
iRaw
ILX Photograph Gallery
30
08-05-2016 04:41 PM
CL-S progression 01
01-26-2016 04:15 PM
dainmezron
10-16-2015 06:56 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
lowgrowl
09-26-2015 05:18 PM
Quick Reply: How to Remove Tumbled Marble Backsplash?
