Heat Pool By Solar Panel?
Old Sep 4, 2012 | 10:18 AM
Renegade's Avatar
Making it Happen
Is there a way to heat an inground pool by a small solar panel? Everything I see online shows rack mounted, roof mounted, huge solar panels to heat the pool.
Old Sep 4, 2012 | 11:45 AM
Moog-Type-S's Avatar
The sizzle in the Steak
Don't most solar pool heating systems circulate water through the panels...and the panels are heated by the sun. Hence why you need a large surface area for the panels to heat the water.
How exactly would a small panel work?
Old Sep 4, 2012 | 12:06 PM
juniorbean's Avatar
^ That is my understanding as well. We looked into doing solar for the house and they explained we could easily add pool heating to it b/c of the large surface area...
Old Sep 4, 2012 | 12:07 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Some women prefer smaller panels
Old Sep 4, 2012 | 10:12 PM
Tehvine's Avatar
6spd FTW
If you have a solid stockade fence on the property that gets a good amount of direct sunlight during the day, you can weave some 1.5" black abs pipe on the back side. Then trickle-pump the water through the piping all day and it'll heat the pool on the cheap.
Old Sep 4, 2012 | 10:24 PM
The Dougler's Avatar
Unofficial Goat
you could perhaps augment a gas or oil fired pool heater with a small solar set up to help maintain temp during the hotter months.
Not sure if this would work but if you were installing an asphalt driveway I wonder if it would soak up enough heat that if pipes were weaved through it that they would soak up the heat from the sun.
Old Sep 6, 2012 | 02:59 PM
CCColtsicehockey's Avatar
^^^ This is a very interesting idea and peaked my interest so I had to Google it. I came up with this article on the idea. http://www.pmmag.com/Articles/Column...00000001111089
Jul 16, 2017 07:33 AM
chasingthecool
Mar 9, 2017 05:16 PM
blacktsxwagon
Oct 27, 2015 10:12 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
