Heat Pool By Solar Panel?
Don't most solar pool heating systems circulate water through the panels...and the panels are heated by the sun. Hence why you need a large surface area for the panels to heat the water.
How exactly would a small panel work?
If you have a solid stockade fence on the property that gets a good amount of direct sunlight during the day, you can weave some 1.5" black abs pipe on the back side. Then trickle-pump the water through the piping all day and it'll heat the pool on the cheap.
you could perhaps augment a gas or oil fired pool heater with a small solar set up to help maintain temp during the hotter months.
Not sure if this would work but if you were installing an asphalt driveway I wonder if it would soak up enough heat that if pipes were weaved through it that they would soak up the heat from the sun.
^^^ This is a very interesting idea and peaked my interest so I had to Google it. I came up with this article on the idea. http://www.pmmag.com/Articles/Column...00000001111089
Jul 16, 2017 07:33 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
