Hard Water Filter (shower)
So as I am down in my basement doing some plumbing I notice that my washer is leaking ...The god damn water pump looks to have shit the bed....Anyways I am looking for suggestions...
Anyone use a hard water filter for their shower? Either a hardwired unit or as a showerhead add on?
Do they work?
Do they work?
They don't make a hard water filter. In order to make the water soft, you need a water conditioner. The most popular are the ones that use salt (brine) to replace the calcium with sodium. These usually require a plumber to install, unless you are handy with plumbing.
You can also have a reverse osmosis conditioner. But they usually use 5 gallons of untreated water to every gallon of softened water.
Sears sells em for about $500...but you can rent the whole shebang from the Culligan man & they'll set it up.
Soft water is a HUGE plus...keeps your clothes fresh longer, keeps YOU fresh longer when you use it to shower also...I used to be able to go a day without the Speedstick when I had mine installed in the last house.
SidhuSaaB
May 30, 2020 12:40 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
STL TL-S
Sep 23, 2015 08:52 PM
