cordless screwdriver
Hi,
I have a Black and Decker 3.6 VersaPak VP750. The battery doesn't seem to hold the charge too long. Every time I want to use it, it need to be charged for hours before I can use it.
So, I can either buy another battery or another screwdriver all together.
The battery alone is $12 (silver) or $15 (gold). seem K-i-n-d-a expensive.
I was in HomeDepot and saw the Skil IXO2 3.6 with an internal Li-ion battery that they claimed that it could hold the charge for 18 months.
Do you guys have any opinion on this Skil? I like the smaller size but how does it stack up with other 3.6v in this class?
Another person looking for a recommendation
My B&D also died. I don't even think I can get a replacement battery for it. It's old and not a versa pack.
I want something that has a long run time.
My B&D also died. I don't even think I can get a replacement battery for it. It's old and not a versa pack.I want something that has a long run time.
Why not just get a Ryobi Drill with the 18v Battery that will fit a variety of things?
http://www.homedepot.com/prel80/HDUS...glo.0&MID=9876
The drill is too big as a screw driver. I fix computer for living. I need something small and easy to carry.
This one looks great. It is the same Li-ion battery one but for only $15.
http://www.harborfreight.com/cpi/cta...emnumber=93690
maybe I will go give it a try.
It's not too expensive and it's a 14.4V. I think you can get it as an 18V.
I have the Sears' 19.2V combo set. (their battery sucks! the set is not expensive though. So it is ok I guess) But they are too big for things like taking apart VCR, DVD player, radio, bathroom heater, fan, etc.
I usually use my B&D cordless screw driver to loosen the screws and then I use it manually to screw the screws back by hand.
I like the size of the Skil iXO2 but the handle is in an angle. That is no good if I want to use it to put the screw back.
I ended up getting another B&D at the HD. I've used it a few times and I like it. It was only $20. Has good power, and the handle can be bent for tight corners.
Everything else started at $40 and up. Some were over $100. For the amount of use I need out of it $20 is fine and if I need to replace it every 5-10 years, that's okay.
AV6driver
Sep 25, 2003 11:26 PM
