Basement Finishing Progress Thread
Old Oct 29, 2011 | 10:02 PM
03tLsNBP's Avatar
MechEng
9 years after we built the house, we are finally getting the basement finished. The basement was basically unusable during the winter and early spring due to the cold and extremely unhealthy during the summer due to the moisture and mold.
Enjoy the progress pictures. It is going to move fast. I will post new pictures at the end of every day or every other day depending on my schedule.
THE BEFORE
Well kind of. We started clearing out the basement and the pics start about 75% of the way through the cleaning.
Old crappy wall I built when I was 13
Moisture warped the panel
Annoying duct
Wall I built when I was 16. Much better construction but still room for improvement.
Old storage room, where did all the stuff go?
Straight into the dining room on the main floor, as well as some other less used rooms in the house
Stair wall panels and door I built when I was 13.
The projector and the riser I built a couple years ago
Old Oct 29, 2011 | 10:03 PM
03tLsNBP's Avatar
MechEng
The Plan
Rough plan:
Old Oct 29, 2011 | 10:06 PM
03tLsNBP's Avatar
MechEng
Day 1
The guy doing the framing and drywall actually does this as a part time job. He works from 8-3 and then goes to his other job doing I have no idea what. Maybe a stripper
Most of the cleaning done
Old Oct 29, 2011 | 10:07 PM
03tLsNBP's Avatar
MechEng
Day 2
If anyone is curious, the ceilings are 9ft height.
Old Oct 29, 2011 | 10:10 PM
03tLsNBP's Avatar
MechEng
Day 3
Monday:
-more framework gets put up
-plumber comes to start installing septic tank and pump for bathroom and kitchen sink
Old Oct 29, 2011 | 11:49 PM
chill_dog's Avatar
Oderint dum metuant.
Great start and plan...looking forward to following the progress. I love threads like this.
Old Oct 30, 2011 | 06:41 AM
svtmike's Avatar
What are you using as a vapor barrier between the framing and the concrete?
Old Oct 30, 2011 | 09:08 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Seems like you guys have a lot of moisture problems, have these been addressed already?
Old Oct 30, 2011 | 10:41 AM
03tLsNBP's Avatar
MechEng
For heat/AC/dehumidification the heating guy recommended this unit:
http://www.acunitdirect.com/lg-tri-z...oor-units.html
As far as putting something like a plastic sheet vapor barrier between the cement wall and the framing, that is a good point. I am not sure why we aren't doing that but the contractor never mentioned anything about putting in a vapor barrier. He knows about the moisture issue. But it's not too late in the process to put one in.
Old Oct 30, 2011 | 10:45 AM
03tLsNBP's Avatar
MechEng
The fiberglass insulation we are going to use has a plastic backing. Is that a sufficient barrier?
Old Oct 30, 2011 | 11:58 AM
svtmike's Avatar
The recent best practice I've seen is spray foam on the walls after framing. But I believe this assumes that the foundation walls are properly sealed on the outside to prevent moisture coming in. General guideline is the vapor barrier needs to be on the warm side.
I take it you've pulled permits and are building to code?
Old Oct 30, 2011 | 12:04 PM
svtmike's Avatar
Here's a decent reference on the current thinking on vapor barriers:
http://www.buildingscience.com/resou...r_code_changes
Old Oct 30, 2011 | 12:15 PM
03tLsNBP's Avatar
MechEng
Hmm I see. I will ask about the vapor barrier on Monday. Thanks for the link
We don't need to get a permit (at least in NY) because it is not labeled as a living space. If we had put in a bedroom, we would need a permit. Plus we would have to put in a door or large window to the outside which would drive up the cost. This basement is for our entertainment only and we have no plans of converting it into an apartment. The builder is building to code as well.
Old Oct 30, 2011 | 12:35 PM
stogie1020's Avatar
Needs more Lemon Pledge
03, regarding the movie viewing area, have you considered placing the seating platforms dead center and having open pass through space on both sides to access the room? I doubt you will notice the slight offset you currently have planned while viewing a movie, but the OCD in me wonders what centering the platform to the room would be like...
If you plan a sound system in there, it might also help dissipate some reverberations from the sound waves if the entrances were open or curtained with fabric.
Old Oct 30, 2011 | 12:49 PM
03tLsNBP's Avatar
MechEng
We would like to keep it a closed room to keep excess noise from the living room and ping pong and foosball table from coming into the theater. There will be sound deadening in that wall and the ceilings.
It would be ideal to place the platforms in the center of the room and make doors on either side but the width of the room is 11ft. The platforms must be at least 7ft wide. That leaves 2ft on either side for doors and that is just too small of an opening to take our large furniture in and out of the room.
Side note:
As of now, the plan is to put drywall on the ceilings in all areas except the theater. The theater will have a drop ceiling.
Old Oct 30, 2011 | 01:17 PM
stogie1020's Avatar
Makes sense. Looking forward to seeing how it progresses.
Old Oct 31, 2011 | 04:18 PM
KaMLuNg's Avatar
in for updates...
Old Oct 31, 2011 | 05:22 PM
03tLsNBP's Avatar
MechEng
Day 4
More framework
Pump this morning before it went in
Pump installed
We decided against the LG heat pump unit. The plumber who came today also does HVAC and said he can do forced air for less than the cost of the heat pump.
Also, my dad asked the contractor about the vapor barrier earlier today but I forgot to ask him what he said. I will find out soon.
Old Nov 1, 2011 | 08:40 PM
03tLsNBP's Avatar
MechEng
DAY 5
More framework, blank spot is where the show piece will go...tentatively. I kinda drew it out in 3D so you can see haha.
Pump and plumbing are done
I'm very tempted to write something in the cement before it dries
I promised you guys there would be picture updates every night except Sundays so hope you all enjoy. I am definitely excited. I am already planning a HUGE Superbowl party
Old Nov 1, 2011 | 10:27 PM
chill_dog's Avatar
I love the daily updates . Your guy makes a good bit of progress each day, too.
You should write something in the cement...how do you not?
Old Nov 1, 2011 | 11:26 PM
03tLsNBP's Avatar
MechEng
We are his only client at the moment so all his focus goes on our basement, which is very nice. He does all framing, drywall, paint, cabinetry, and tile work himself (literally only him) which saves him and us A LOT of money. And he has done very professional work so far. I really don't know how he does it himself. He's like 5' 6" maybe 140-150 lbs, probably in his late 30s. Minimal tools too. I guess he's really good at what he does.
Only things he gets someone else to do are carpet, countertops, plumbing, electrical, and HVAC.
Also, I failed I didn't write anything in the cement before it dried.
HVAC work starts tomorrow supposedly.
EDIT: Crap I forgot to put Day 5 as the title for pictures from 11/1/11. Maybe a mod could be so kind as to add that? It's just a bit of OCD on my part. I want this thread to be really neat and organized
Old Nov 2, 2011 | 08:34 AM
(Mid-Atlantic)
added day 5 title, keep the updates coming
Old Nov 2, 2011 | 09:19 AM
03tLsNBP's Avatar
MechEng
Thanks and will do
They actually need to move the water heater over to the right about a foot today to make room for the new HVAC unit. So my guess is that duct work will begin tomorrow, not today. New pics coming tonight as usual.
Old Nov 2, 2011 | 10:21 PM
03tLsNBP's Avatar
MechEng
Day 6
Man what a long day. Out of my house by 7:30am, just got home. I'm beat. But I was pleased to see quite a bit of progress
Old wall I built was taken down today
That awkward duct work is being fixed
Heating unit
Old Nov 3, 2011 | 08:40 AM
Scrib's Avatar
Administrator Alumnus
Make sure you're leaving yourself enough room to do maintenance and at some point perhaps have to remove the HVAC unit and hot water heater.
Old Nov 3, 2011 | 09:48 AM
svtmike's Avatar
Is there a floor drain in the HVAC room?
Old Nov 3, 2011 | 11:25 AM
KaMLuNg's Avatar
at first i thought that was a sump pump, then i realised you are using it to discharge the waste water... how fast can it move the water? will it keep up with a shower?
if you don't mind me asking, how much was the pump?
Old Nov 3, 2011 | 02:24 PM
03tLsNBP's Avatar
MechEng
HVAC room has two doors and is up to code. HVAC guys said they wouldn't have a problem.
No floor drain but the units are hooked up to their own pump.
No shower in the bathroom so it shouldn't be an issue. Ill get back to you on pricing and specs. I can't remember at the moment.
Old Nov 3, 2011 | 02:28 PM
03tLsNBP's Avatar
MechEng
You know now that I think about it I the doors in the HVAC room are 30 inches. Maybe we should just make at least one opening 36 inches for good measure. I will talk to my dad about it tonight.
Old Nov 3, 2011 | 08:17 PM
03tLsNBP's Avatar
MechEng
Day 7
All HVAC is done I believe
The left most duct going the length of the basement is the new one they put in today.
More new frame work in theater
Old Nov 3, 2011 | 08:19 PM
03tLsNBP's Avatar
MechEng
Turns out my dad doesn't know the price of the pump specifically because the price we got included installation and HVAC and everything. If we get a breakdown of the bill, I'll let you know.
Old Nov 4, 2011 | 10:19 PM
03tLsNBP's Avatar
MechEng
Day 8
Not much completed today, just kitchen walls.
Old Nov 5, 2011 | 01:24 AM
chill_dog's Avatar
^It's Friday...contractors knock off early on Friday . Still, lovin' the progress and the updates.
Old Nov 6, 2011 | 01:18 AM
03tLsNBP's Avatar
MechEng
Day 9
More progress on the theater
Old Nov 7, 2011 | 10:38 AM
03tLsNBP's Avatar
MechEng
Day 9
Had to organize some files, pictures got moved. So here is Day 9 again.
Old Nov 7, 2011 | 11:17 PM
03tLsNBP's Avatar
MechEng
Day 10
Not much completed today. Looks like work is slowing
Bathroom is completely framed
Some other small framing stuff was done near the new gym but nothing picture worthy.
Also the AC unit was installed outside but I didn't get a pic of it. Maybe tomorrow.
Old Nov 8, 2011 | 07:08 PM
03tLsNBP's Avatar
MechEng
Day 11
Showcase thing. He couldn't do the arch for whatever reason.
Storage room door finished
Old Nov 9, 2011 | 10:25 AM
KaMLuNg's Avatar
so a sink and toilet? that pump can move solids?
Old Nov 9, 2011 | 11:02 AM
03tLsNBP's Avatar
MechEng
Apparently. I guess ill find out the first time i break in that toilet haha.
Also sorry I still haven't gotten you any info on the pump. Ill see what I can find out tonight.
Old Nov 9, 2011 | 01:21 PM
KaMLuNg's Avatar
no worries.. don't kill yourself over it... i just wanted an idea but will look into more when i am serious enough to need it...
