AC Question....
Old May 26, 2009 | 12:21 PM
coykiam's Avatar
AC Question....
Ok guys its that time already...I need to get a new AC, preferably a wall unit. Can anyone explain why do wall units cost twice as much as comparable window units?
Old May 26, 2009 | 01:29 PM
doopstr's Avatar
Been a long time since I was in a house with a wall unit, but I believe wall units have an external "cage" that you somehow need to mount and then the unit slides into that.
They shouldn't cost twice as much though. Did you compare the BTU ratings?
Old May 26, 2009 | 01:39 PM
coykiam's Avatar
yupz....was looking at the ones that are around 8000btu. The window units are around $200 more or less and the wall units are around $400-$500...
Reason im looking for a wall unit is because I have an old wall AC unit thats currently installed and is no longer working. For the past few years I just used a window unit, And Just last year I threw the window unit because it was getting noisier and had cracked on the frame. I would like to utilize that wall and not give up a window again.
Old May 26, 2009 | 03:56 PM
moeronn's Avatar
is learning to moonwalk i
I don't know why they are so much more expensive, but that is what I need as well. From what I can see, the main difference is the wall units have vents only in the back and window units have vents on the sides and back. I'll probably be spending around $500 to replace mine
Old May 26, 2009 | 11:22 PM
Chr8808's Avatar
Are you accidently looking at heating/cooling units? hvac/ptac?
Old May 26, 2009 | 11:36 PM
moeronn's Avatar
^^ Adding heating usually adds another ~$100, but is a separate issue that through-the-wall vs. window units.
2low2go
Oct 26, 2021 09:27 PM
riefel182
Mar 23, 2010 02:06 PM
TS_eXpeed
Cameras & Photography
21
Jul 31, 2008 08:47 PM
Acura Sensei
Sep 12, 2002 08:45 AM
ChrisKelly5
May 6, 2002 05:14 PM
