? about replacing water heaters
When you replace a water heater, do you have to get the same size or can you go smaller? Our condo has a 72 friggin gallon gas tank. I guess the previous owners looooved them some hot wata! Anyway, I purchased a 40 gallon tank at lowes. Is this ok to use? The specs for a 40 gal tank say it's ok for a family of 3-4. Our condo is 2bd 2ba which I think a 40 gal will work fine. Thoughts?
Family of 3 we had a 50 gal electric and it was fine in a 3BR 2 ba house.
You should be fine with a 40 gal gas, as they recover pretty quickly.
A 72 gal, holy crap what kind of gas bill were you running keeping that thing hot?
Even here we have a 50 gallon. We've had up to 3 people showering at the same time, with another showing right after, and we had plenty of hot water... so you should be golden.
Originally Posted by doopstr
Check to see if you township requires a permit to change the tank. Mine does. When I went to sell my townhouse I had to get a permit for a tank I had put in a couple years before.
Originally Posted by mc_yanzo
How long do long does a water heater last, on average? I checked ours and it was put in April 2000, so I want to know how much longer I have.
10 - 15 years. There are some steps you can take to extend the life of it.
our old water heater was from 92. From what I've read, they can last 20-30 yrs if properly maintained. Ours died from corrosion and sprung a leak. BTW, fukin plumbers took me for $65 on the straps to hold the heater down in case of an earthquake. They said they were replacing with thicker straps because they have to replace everything to code. I come back and check their work an hour later and it looks like the same straps I had on there before. I was pissed of course and couldn't do anything about it since they were done. Complained to Lowes about having shady contractor rippin me off. There was nothing wrong with the old straps. They could have been reused. Matter of fact, I think they were replaced only less than 2 yrs ago.
Bump.
Is it best to replace the H2O heater before it dies, or after the garage gets a good soaking from it? My house was 7years old when I bought it,and have been here for 2 years. The WH was a "7 year" model. I don't get really hit water like I did when I moved in, but I get hot water. Should I just get it "serviced" and if so, what do they do to "service" it?
Bump.
2) There is an anode rod/metal rod inside the water heater which wears out and must be replaced after several years.
3) The pressure relief valve is to be tested (and replaced if defective).
The tankless is for two bathrooms. There are also two other water heaters for the rest of the house.
My grandma's water heater was built in 1986. It's even got the fake wood grain on it! However, the thing looks like it's in mint condition. My dad (who is in the trade) says it's a ticking time bomb basically.
My parents replaced their water heater a few years ago. The original water heater (dated 1996) got eaten up by hard water.
I think it all depends where your water heater is stored and the quality of your water. Older homes here in CA have the water heater indoors (my grandma's is in a closet), newer homes have the water heater either outside in an enclosure or in the garage. I would think that the more protected the heater is from the elements (temperature changes, extreme colds and hots, bad weather, etc.) the longer it'd last
EE4Life
Sep 11, 2015 10:13 PM
asahrts
Sep 4, 2015 05:55 PM
