How's this workout plan?
That's Racist
![Lightbulb](https://acurazine.com/forums/images/icons/icon3.gif)
Hi guys, now being that I am back in school and in full swing of things (essentially 8am to 6pm class/work/meetings days), I am finding less and less time to be able to spend in the gym (unlike the 2 hours a day and 5-6 times a week minimum I had during the summer).
In any case, I am only able to spend about an hour each time in the gym, long workouts just cut way too much time into my studying... so how does this sound?
*Note: All lifting is upon Abreece's tips. High intensity heavy weight lifting. I usually pyramid the weight and reps for 10-8-6-4 reps and upping the weight. Essentially, I lift until I sweat.... everytime.*
Mon - Assorted cardio (running/stadium stairs/running sprints/boxing and jumprope/breakdance/random cardio machines/etc.)
Tues - Chest and Back
Wed - Cardio/shoulders
Thurs - Biceps and Triceps
Frid - Lowerback, legs, shoulders, cardio if I have time
Sat/Sunday - Cardio and or recovering from hangover
-Just a note, I am not able to do cardio really quickly right after each workout, as waiting for a machine at my overcrowded school gym can end up equalling about 20-30 minutes just for the wait alone. To me, it's just too much of a waste of time.
-I'll figure out a way to throw in abs once I start losing some fat and the muscle can actually show (or should I just start on the abs right away, as I'm not horrendously fat, but would still consider myself a meaty fellow).
Moderator Alumnus
well this is my schedule and it has been working great for me so far:
mon: shoulders/biceps
tue: chest/triceps
wed: back/legs
thu: shoulders/biceps
fri: chest/triceps
little bit of cardio everyday, low reps high weight
tue: chest/triceps
wed: back/legs
fri: chest/triceps
That's Racist
tue: chest/triceps
wed: back/legs
fri: chest/triceps
tue: chest/triceps
wed: back/legs
fri: chest/triceps
I just wnated to see if anyone else did cardio on totally separate days.
Moderator Alumnus
Originally Posted by Time For Sleeep
I suppose that's the problem. I dont' have enough time essentially to do a bit of cardio everyday, considering I would run a mile on the treadmill a day, that would easily kill about 45 minutes that could be spent doing homework... =/
I'd suggest SOME rest in there, at least 1 day off. Just my take on how important an off-day is with any regimen.
One other thing sticks out - delts. You work chest and then delts 2x a week. Are your delts lagging? That might be a little too much for such a small muscle group. If you want to hit delts 2x a week, I'd suggest doing them same day as chest and then the same day at tris/bis. That way you have enough rest in between delt sessions, but still hit them 2x a week. Also, you should be able to mix in delts, bis and tris in the same session and keep it under 45 min, 60 tops.
Lastly, don't just throw in abs when you can, strong abs = strong all around lifting. People neglect abs when in fact they should work them 1-2x a week. Just think about how often abs come into play when lifting? A great tip is to do weak/neglected muscles FIRST instead of just throwing them in at the end, since that is usually how they won't get any attention.
That's Racist
In actuality, my delts really aren't that lacking. Would it be better to just do them once a week?
Maybe I should buy a jump rope and just do a good 15 minute jump rope session before I start lifting. Does anyone know how good of cardio jumproping is in comparison to running?
I'll take the abs workout tip into consideration too.
My rest days are essentially on weekends. I count my gym time in work week terms. This is because my weekends are usually packed, and or I go home and have no time for the gym.
If you want to split everything and not train certain things 2x per week, you could go:
back/biceps
cardio
chest/triceps/shoulders
cardio
legs/lowerback
rest
rest
Or something of that sort. If you are fairly new to lifting, maybe a push/pull or an upper/lower or full body workout will be more suitable.
Originally Posted by PerfectlyImperfect
back/biceps
cardio
cardio
legs/lowerback
rest
rest
![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
Originally Posted by ABreece
This is pretty much my split, only i work the lower back with my other back exercises, and I skip cardio ![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
![Roll Eyes](https://acurazine.com/forums/images/smilies/rolleyes.gif)
My cardio is minimal. My light days account for cardio. Lighter than usual weight + less rest between sets + more reps = Glycogen Depleted Lovliness. I honestly think it's harder than cardio...hence the reason I suggest a push/pull split.
Since you work lower back with other back exercises, do you do deadlifts on back days? Or do you do them on leg day? Am I being too nosey?
I know you asked Breece, but wanted to add that I personally do lower back on back day, which includes deadlifts. I work my lower back with good mornings more than anything.
My rest days are essentially on weekends. I count my gym time in work week terms. This is because my weekends are usually packed, and or I go home and have no time for the gym.![Frown](https://acurazine.com/forums/images/smilies/frown.gif)
Also, you might think about NOT doing any warmup before lifting - I used to do that, but on the advice of gavrill, I just went straight into my lifting routine. Even though I was skeptical, I tried it and will admit that I have been able to lift more weight without sacraficing anything, like form or "comfort" level. Just something to consider.
And definitely think about the abs - you are only as strong as your weakest link and abs come into play more than you think. Core strength should not be neglected.
Good luck dude and kick some ass!
Skip cardio?!?! Blasphemy! I really hate you people that can get away with that. ![Roll Eyes](https://acurazine.com/forums/images/smilies/rolleyes.gif)
![rofl](https://acurazine.com/forums/images/smilies/rofl.gif)
Interesting...since deadlifts hit the hammies, too. I guess it really doesn't matter if you rest enough between back day and leg day. I never felt "right" doing them on leg day...nor on back day. In any event...I think that putting stress on the fibers 2x per week is more beneficial. Just my ![2 Cents](https://acurazine.com/forums/images/smilies/2cents.gif)
Adam, are you one of those non-cardio people that I hate like Breece?
That's Racist
I've modified my workout plan since the day I started the thread; any advice on this would be helpful; it's been great for me so far this summer as my diet has cleaned up A LOT to accompany it ![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
Mon - Chest and Tri's
Tuesday - Cardio + weighted abs (stadium stairs)
Wednesday - Back and Biceps
Thursday - Cardio + non- weighted abs (sprints + other HIIT)
Friday - Shoulders + Legs
Suggestions? Critiques? Thx y'all
