Jack points at the frontal section of the car
No-navi, yo
Originally Posted by TSXTuner
Needed :
Hydraulic Floor jack, jack stand, 10 mm wrench, 17mm wrench.
Drain Pan. Funnel. Paper towels.....
Jack the car up from the drivers side front wheel, from the lower control arm
or from a heavy section of the main frame rail from a location
just rear of the front wheel. The - in the A of the lower control arm is a good
jack point for the hydraulic jack.
Place another good quality jack stand under heavy the main frame rail at a location just rear of the front wheel.
Never go under a car with just the hydraulic floor jack.
Also have a jack stand(s). ...
TSXTuner
PWP auto no navi
Comptech springs
Red K&N CAI
Hondata heat gasket
Throttle bypass mod
Polk db650 door speakers ( 4 )
Comptech rear sway bar
DC sports header
M3 style lip spoiler
18" Kazera Rims with Fuzion P225/45R18
SilverStar high beams
TSXTuner
PWP auto no navi
Comptech springs
Red K&N CAI
Hondata heat gasket
Throttle bypass mod
DC sports header
To change engine oil myself, I ordered ramps from Sears. The reasons I wanted to get ramps instead of hydraulic floor jack are: 1.) I don't have a lot of space to store floor jack; 2.) I am not sure if I can raise the frontal side of the car high enough from the jack point stated in the manual (rear center, under the trunk) for oil change.
Then I saw this post, describing one can jack up TSX directly from the frontal section of the car. And I found this hydraulic jack from Sears website (link below). I am wondering can anyone provide some more descriptions on where are the jack points at the frontal section of the car. I know the L-shaped plates where the jack stands should go, but I am not certain where are the locations that I can jack up the car using the jack. Any comments and suggestion on the jack points or the hydraulic jack will be appreciated.
http://s7.sears.com/is/image/Sears/0...=0.5,1.0,0.0,0
My Garage
Originally Posted by mg7726
perfect shots of the front and side jacking points:
https://acurazine.com/forums/showthread.php?t=27088
what happened to your owners manual??
Plus there is a GINORMOUS arrow pointing right at it
No-navi, yo
Thanks for the speedy reply. From the second picture, I guess another service panel (different from the one to drain engine oil) need to be removed in order to access the jack point.
My owner's manual is in the car. I thumb through it, but don't recall finding any description on the frontal jack points, only the rear one under the section for tire rotation. I will check the manual again.
No-navi, yo
From gsclifton's thread:
No-navi, yo
Originally Posted by jlukja
You don't need to remove anything to access the front jacking point. Just look under the front bumper, its exposed.
Ahh, I do remeber there was a (significant) horizontal metal bar located around the area. I guess that is the structure could be used to support the car??
I have a 04. Mine has two rectangular metal loops, about the thickness of a thumb. It looks like you can slip a hook through it for towing. I used that as the jacking point. Its attached directly to the frame and is SOLID.
No-navi, yo
I flipped through the manul again, but did not see any information on the frontal jack point.
I have a 2004 as well. I guess I will try to find the arrow and compare to the pictures tomorrow. Thanks for all the help.
Now, any comment on the hydraulic jack?
Not familiar with the hydraulic jack in the picture in your link. The jack I used when installing my mods was my dad's jack and it was the same style as the blue one in the pics above. I remember that my dad's jack didn't raise the car high enough to slip the jack stands under the sides. I needed to add a 5" piece of wood as a spacer (which is bad practice and I shouldn't have done it). The jack needed should be minimum 2-1/2 ton and which should raise the car at least 17" (this was the minimum for my dad's jack stands and gets the tires off the ground by about 2"-3"). Also need two jack stands. Don't get under the car with only the jack supporting it. Always use jackstands.
No-navi, yo
http://www.sears.com/sr/javasr/produ...id=00950281000
Darn, the hydraulic jack (without 'floor' in its name) only goes to 15-3/8 inches (see link). Can you explain why it should be more than 17"? Thanks, mod!!
The stands you buy/have might be different. I don't have the jack here anymore, I returned it. My advice is to wait a day or two and see if someone posts about a jack they have that works for them.
No-navi, yo
^^ Got it.
I went under the hood to check the jack point indicated by the arrow. It was very obvious, and probably the only area at the frontal section that is exposed. I wish I have found it out earlier.
No-navi, yo
Shor review on the jack
I went ahead and bought the hydraulic bottle jack, along with the 2-1/4 ton jack stands (Craftsman) from Sears. I did not want to wait any longer to change the engine oil; I had done so using these new toys. I took a few pictures. I guess I could send them via P.M. for those who want to see.
First, the minimum height of the bottle jack is more than the ground clearance of TSX. So in order to place the bottle jack under the car, I had to raise the car with the "spare tire jack" first. Using the bottle jack, I was able to lift the car high enough so the front wheels were about a inch in the air, which gave me enough space to work and apply jack stands to support the car. I was able to raise the car higher, but there was no point. However, I wonder if I could lift the rear wheels above the ground using my bottle jack.
Bottom line: A hydraulic floor jack should be more practical than the bottle jack that I bought, but the bottle jack gets the job done, and is easy to store, which is what I need.
No-navi, yo
Originally Posted by moda_way
One other point should be mentioned, bottle jacks don't typically have a large jacking point, making the car less stable once you get the wheels off the ground. Jack stands are always necessary if you are going to be under the car for safety. Bottle jacks are great for lifting via the side jack points and storage, but I wouldn't get one for lifting the front. Go with the floor jack and get everything you need.
But I am going to keep my bottle jack, mainly for lifting the car, so I can apply jack stands. I would no way go under the car with the support only from the bottle jack, using no jack stands.
No-navi, yo
Originally Posted by JTso
Be very careful with the placement of the bottle jack. The small contact surface puts all the pressure at the center point can potentially punch a hole or put a dent in the sheet metal.
Oakes
Wash & Wax
10-12-2015 11:17 AM
