Broken sensor connector pin 2008 rdx
Hey everyone,
I was doing a DIY starter replacement on my rdx and realized upon removal I broke a sensor pin and couldnt put the female end back on it.
the location is a little away from the starter to the left. And the connector is attactehed to the wiring harness that sits in from the starter.
I have attached some photos of it. What it should be and what it is now.
please any advice would be great.
I just need to know which kind of sensor it is and how to fix replace etc
thank you
thank you
I'm about 90% certain that's the coolant temp sensor. It should be a 24 mm socket to remove the whole unit and then just put a new one in. Obviously coolant will come out so be quick with the swap to lose as minimal coolant as possible.
-Shane
-Shane
NavTool
19
05-16-2014 07:26 PM
mattrush78
08-25-2002 11:58 AM
SC TL
04-04-2001 12:41 AM
