Anyone know a good Mechanic (brakes) in GTA?
Old 08-17-2011 | 05:53 PM
DejaVu85's Avatar
śïιέит вµт đέαđιý
My TL is giving me some sort of problem with the rotors/brakes.
When I drive fast and push the brakes, my brake pedal and steering wheel shake.
When I drive slow and press the brakes, I sometimes get a squeaking sound.
I have slotted front rotors with EP300 pads(from Heeltoe) in the front, which I put on like 3 years ago. The pads are still in good shape.
I was told these rotors I have don't easily warp, so it should be something.
- maybe a wheel speed sensor
This is my second set of rotors for this car since I got it, I don't see how it can keep warping withing 2-3years of driving. The OEM ones were warped according to the dealer and that's why I got these Racingbrake ones from Heeltoe.
I'm looking for a good shop that will actually take a look at these and figure out whats wrong with it, instead of just saying change the rotors and pads.
Any suggestions/referrals?
Old 08-17-2011 | 08:05 PM
gnuts's Avatar
3.5 psi
brakes are a staple job for any shop. When you feel it in the steering wheel it's usually warped rotors.
Check out B-Line Mechanics:
Location/Contact info: 1829 Britannia Rd. East Unit 4, Mississauga, Ontario
Phone #: 905-696-9576
Old 08-17-2011 | 08:06 PM
hnirtymmot's Avatar
AdvancePowerHouse
- out of all the shops i know of and i work at a dealer and i still willing to go to them
1217a lawrence avenue west,
toronto ontario
m6a 1e2
416 781 8671
Old 08-17-2011 | 09:53 PM
GTSX-05's Avatar
ASM 3G TL Type-S
Originally Posted by hnirtymmot
AdvancePowerHouse
toronto ontario
m6a 1e2
416 781 8671
second it
Old 08-18-2011 | 08:25 AM
mau108's Avatar
Also get a brake fluid flush done as well (suck exisitng brake fluid out using turkey baster, put new fluid in and then bleed the brake lines)
But you may have to replace the rotors as well as the damage is already done to it (I find OEM rotors the best and I've tried a lot of brands).
Old 08-18-2011 | 09:02 AM
TmaX's Avatar
UA7 6MT
I would also recommend this as well.
Your breaks will feel much more responsive and the pedal feel will be greatly improved.
Check out SpeedStar for your needs.
Either Elliott or Frank will be able to help you out for sure.
They put my current ASPEC pads in alongside a flush at the same time and I couldn't be happier with the pads and their work.
Hope to see you at the meet!
Old 08-18-2011 | 10:55 PM
guitarplayer16's Avatar
Chi from 360 Auto has excellent reviews for good service and excellent pricing.
Old 08-18-2011 | 10:59 PM
Ch33sE1's Avatar
I got my stuff done at APH and SR. Both shops are introduced by Nextmod and they do really good work.
kmawani
02-08-2023 05:09 AM
cycdaniel
12-17-2019 10:58 AM
NSolace
09-03-2015 08:02 PM
Quick Reply: Anyone know a good Mechanic (brakes) in GTA?
