Need a new grill (somewhat of a noob)
My current grill is pretty old, and I'm looking to get a new grill..
Current grill - gas with lava rocks
Apparantly they dont make gas grills that take lava rocks anymore.
How exactly do new gas grills flavor the food? And are they actually better than the old lava-rock grills? For that matter, why did lava rocks go out of style?
Next question: charcoal grills. Coals catch fire, and they keep burning right? Does this mean you can only use coals once, then you throw them out? Are can you reuse them all summer long? Likewise, if one were to use woodchips, are the chips a one & done thing?
Third question, what do you personally prefer/why?
What replaced rocks are sear plates. They basically sit over the flame. When the drippings drop down they hit the plate and create smoke/flavor.
Use charcoal once then throw away.
I like gas because I'm lazy. Its easier to get going than charcoal.
I don't have a Ferrari in
I have no idea what Lava Rocks are, sorry.
As for charcoals, once you burn them, they're spent and can no longer be used again. They usually will burn for 2 hours so you'll have more than enough time for a good BBQ. To light charcoals, you dump some lighter fluid on them and light it, wait for about 15 minutes then they will be damn hot. You can't control the temperature (Gas +1) but the flavor will be better (Charcoal +1).
I wouldn't use woodchips for continuous cooking because they are usually more expensive and are better suited to flavoring. There should be either a container made for charcoal grills to put woodchips in or built in containers on gas grills that you can slide out. I like hickory.
I prefer charcoal simply because it tastes better. I don't care about convience. It takes me about 2 minutes to light it and I just walk away for 15 minutes while I prep what I'm about to cook. Charcoal is usually cheaper as well both grill and briquets (Charcoal +1).
2 vs 1. Charcoal wins.
Flavor is still a bit lacking but it somewhat, though not completely, makes up for it in the convience department
i think the plates are supposed to give more even heat. We bought a cheap gas grill a few years ago, and it didn't dissipate heat well at all even though it had those plates over the flames. It would be much hotter right over where the flames were. We just bought some lava rocks and filled the thing up anyways, and it works a lot better.
The Creator
http://www.virtualweberbullet.com/chimney.html
If your grill has vents you can control temperature. Certainly not as well or as easily as you could with gas, but you can definitely get a wide range of temperatures by adjusting bottom and/or top vents.
^werd, I bought my dad that weber chimney, his old one was falling apart. Chimneys are also nice so you can start heating up new coals if your other ones start losing heat, without having to take off all your food and stuff. Just make sure you have a safe place to light a fire.
A lot of people swear by natural charcoal as well rather than the briquettes. I haven't seen it sold too many places though.
Originally Posted by soopa
nooooooooooo! coals should be lit with a chimney, not chemicals.
Important: Never light a chimney starter directly on a concrete surface. Heat from the chimney may cause the concrete to explode, damaging the concrete surface and possibly causing physical injury.
![what](https://acurazine.com/forums/images/smilies/what.gif)
quanaman
01-09-2023 07:33 PM
