Windows Xp question... please help !!
Old Feb 10, 2005 | 08:14 PM
Intox1221's Avatar
registered !!
Ok so i have had professional on my Dell desktop since i got it. And then i downloaded the SP2 update ( a couple months ago) and it started doing weird things to my broadband internet... on the first instance the data light on the modem would go out or started blinking, well in short, i started having problems with the internet, and then i uninstalled SP2 and everything went back to normal... no problems...
and then after a while, i again downloaded SP2 (like two days ago) and installed it on my desktop, ok everything seemed to be fine for like a day or two, but then after like two days of installation the internet started working really really slow (nothing wrong with the modem this time)...
now here is the kicker, my laptop has SP2 installed in it since i got it thru factory, and that has given me no problems at all, i have a router, so i plug my network cable directly into the laptop if im not using the wireles... and it gives me NO problems...
And now i finally got done uninstalling SP2 on the desktop and voila, everything seems to be in order...
Does any one have any explanation for this ???
Old Feb 10, 2005 | 08:16 PM
Ken1997TL's Avatar
XP service pack 2 is filled with bugs. Its affected MANY people, look it up online.. its just awful.
Old Feb 10, 2005 | 08:24 PM
Intox1221's Avatar
registered !!
i guess that explains it... i mean with or without SP2 is fine by me, i jus like to keep my stuff updated and all, and then i really liked the pop up blocker in IE, i know there r many pop up blockers out there, but it just seems to be imbedded with IE and work better, to me atleast... o well... looks like im not the only one without SP2...
Old Feb 11, 2005 | 10:10 AM
Billiam's Avatar
Big Block go VROOOM!
Or do a search here, there's been plenty of discussion on it in the past. For every person that shares Ken's opinion, you'll find one that does not. Myself included.
Can SP2 cause problems? Absolutely. Is it riddled with bugs? No. IMO, 80% or more of the problems encountered with SP2 were the result of unupdated or poorly written drivers, unupdated or poorly written applications, or pre-existing configuration problems that weren't noticed before. We have deployed SP2 on over 400 machines at work with probably a > 95% success rate. I bet I could count on one hand the ones that had problems that weren't already riddled with viruses, spyware, etc....
Anyway, make sure everything on your problematic machine is up to date and then make up your own mind after doing research.
Old Feb 11, 2005 | 10:37 AM
BEETROOT's Avatar
Yeehaw
to Billiam.
I have it on all my personal PC's, and I am in the process of putting it on all the PC's in my office. No problems on anything yet.
Is your firewall on Intox?
Old Feb 11, 2005 | 01:26 PM
HEKURTSEHU's Avatar
with SP2 you just did what your avatar shows - except you were holding the gun & pulled the trigger
Old Feb 11, 2005 | 01:45 PM
sixgearcl's Avatar
Registered Douchebag
make sure to uninstall any other firewall you may have.. that often causes conficts
Old Feb 11, 2005 | 04:38 PM
ib_jimmy's Avatar
i dont know about SP2 being buggy....have it installed in all my personal computer and work computer and it work fawlessly....only time i've encounter problem after installing SP2 is went the computer is infected with adwares, spywares, viruses worms...etc...just gotta make sure before u install SP2 that ur computer is clean of all those bad file and that all drivers are updated with the latest driver.
Old Feb 11, 2005 | 05:52 PM
joeshmoe's Avatar
My Home Planet
I waited a long time to install SP2 on my home laptop. I decided the best way to do it without facing any problems would be to do a clean reinstall of XP and update it with SP2 before I reinstalled all my programs.
Old Feb 12, 2005 | 02:40 AM
Intox1221's Avatar
registered !!
Yess as a matter of fact it is !!!... guys i am all for updating and keeping my computer bug/virus/spyware free, i have a dell 8500 and it has legit softwares and factory settings...
I have symantec client firewall, which i bought from school which is offered to students at a very attractive price... soo before i installed SP2, i had that firewall running... was that the cause of the problem... if i remove the firewall... install SP2 and then install the symantec utility.. will that help ??? please help me out with this... as much as the most of you, i luv to keep my shit updates and running good as new... thanks...
Old Feb 12, 2005 | 04:33 AM
Hobo's Avatar
Flap.
solution : firefox
Old Feb 12, 2005 | 03:50 PM
CLSter's Avatar
Under the radar
It seems that doing a full driver update check, full spyware check, disk cleanup, then disk Defrag before doing the SP2 update is the way to go. Worked much better that way for me and some people I know. And yes Firefox is the only way to go for web browsing.
Old Feb 12, 2005 | 04:03 PM
Intox1221's Avatar
registered !!
i have tried firefox, and maybe im a :noob: with this, but i couldnt get it to download a file or program to any other location except deskptop... what gives ???
and thanks for the input all of u guys... i'll try the things listed above and see how it goes... ...
if u have more suggestions, keep em coming ...
Old Feb 13, 2005 | 01:15 AM
CLSter's Avatar
Under the radar
You tell FireFox what you want: Go To TOOLS ===> OPTIONS ===> Downloads, look to the upper right on that screen, all the DL options are there.
Old Feb 13, 2005 | 01:23 PM
Intox1221's Avatar
registered !!
Sweeeet... ....
le^2
Mar 17, 2026 05:06 AM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
AcuraKidd
Sep 25, 2015 11:18 PM
