Motherboard problem
Old Aug 14, 2006 | 10:58 PM
ryder1650's Avatar
Motherboard problem
I just bought a new motherboard (Intel D975XBX) with Core 2 Duo E6400. I have hooked up all the power cables and fans etc, however, when I press the power button nothing happens. I have tried 2 power supplies and have disconnected and reconnected everything many times to no avail. I thought the mobo and/or processor were bad, so I went back to Fry's and exchanged both of them, and it still does not work...
TIA
Old Aug 15, 2006 | 05:33 AM
Dan Martin's Avatar
Photography Nerd
Did you connect the power button to the motherboard?
Old Aug 15, 2006 | 08:59 AM
badboy's Avatar
First check to see if the power button is properly connected to the motherboard.
Some motherboards have a small light on them somewhere which is always lit when the motherboard is getting power. Check that.
Check the back of your power supply, there is a switch to manually stop any power coming in. It should be black with "l" and "O" written on it.
You said nothing happens, but I am going to ask this anyway, do you hear any beeps when you hit the power button?
Old Aug 15, 2006 | 10:54 PM
ryder1650's Avatar
The power was connected and the light on the motherboard was on. I know now that it is a short of some sort caused by the new chassis I bought. If I assemble it outside of the chassis everything works fine. I cheaped out on the chassis and am now seeing the results...time to return this POS and get a much better one.
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
