logitech driving force pro wheel is broke--help!!
Old Jul 13, 2005 | 01:15 PM
AS3.0CL's Avatar
F1 cart racer
ok so here' my problem, i have had it for more then a year. about a month ago the break sensor registered that i was breaking but just a little bit in GT4. so if i pushed the pedel from the side it would go away since there is some left to right play in it. i took it apart and just looked at everything and moved it around and i put it back together and it worked fine, it still had the play in it was fine.
last night when i went to go play i had the same problem so i did the same thing figuring it would be fixed. well after i put it together the break does not work at all. it won't register that i'm breaking.
any one have this problem or have an idea how i can fix it?
Old Jul 13, 2005 | 01:20 PM
Billiam's Avatar
Big Block go VROOOM!
I may have some advice but I have a question first. Are the DFP pedals single axis or split axis?
Old Jul 13, 2005 | 01:26 PM
AS3.0CL's Avatar
F1 cart racer
ok i'm not that technically inclined but when u open it up there is a plug with i think 3 or 4 cable going to it into the side of the pedal, there is a different one for each side, i'm not sure if this answers your question but if anyone else has info about this please put it in. thanks. i don't feel like buys another $150 wheel.
Old Jul 13, 2005 | 01:42 PM
Billiam's Avatar
Split axis means the brake and throttle operate independantly of each other. Single axis means that they are two sides of the same axis. In a single axis setup if you have the throttle floored and push the brake it just reduces the amount of throttle and doesn't actually register any braking. Which way is the DFP?
What I would suggest doing is testing like I mentioned above. Floor the throttle then step on the brake and see if the thottle level stays the same or goes down. Then do the opposite, floor the brake and apply the throttle.
I took apart my red Logitech Mom Force once (split axis) and thought the brake was screwed. It turned out I had just put the leads to the brake pot on backwards when I reassembled it.
Old Jul 13, 2005 | 02:23 PM
AS3.0CL's Avatar
F1 cart racer
when i floor the throttle and then presson the break the throttle would hold wide open at the same time with the break. now if i floor the break i can also floor the throttle. so this means that it does not reduce the gas at all. so i believe it is split axis. but at this point the break does not work at all it won't even register. i know i hit the plug where it it connects to the break but it didn't come off or anything.
Old Jul 13, 2005 | 03:33 PM
srika's Avatar
Moderator Alumnus
honestly, if I were in your shoes, I would throw it out and get a new one. when you break a steering wheel, there is often nothing you can do, unless you have the extended warranty on it - then you can return it and get a new one - I've actually done that before.
what I mean is - there are usually no user-serviceable parts inside a steering wheel - if something breaks, its broke.
but let me ask you this - when you click on Game Controllers and go into that window, when you press the brake, does it show the red bar going up and down? If not, try calibrating it from within that screen - if that still doesn't work, try reinstalling the drivers. If still no sign of movement when hitting the brake, I would have to say you're SOL.
Old Jul 13, 2005 | 05:13 PM
Billiam's Avatar
If it's just a dead pot on the brake pedal he might be able to get a replacement from Logitech or Radio Shack for that matter if the specs can be found.
Old Jul 13, 2005 | 05:22 PM
srika's Avatar
Moderator Alumnus
oh... yeah. what he said.
Old Jul 13, 2005 | 06:52 PM
AS3.0CL's Avatar
F1 cart racer
i'm gonna try to clean up the inside maybe it's not making a connnection with all the grease and all the dust thats in there, if not then i'll do that
Old Jul 13, 2005 | 10:53 PM
Billiam's Avatar
Just remember, there's no rule that says you can't have the thing plugged in and be testing it while you have it taken apart. That way you can try turning the brake pot and jiggling the wiring with your fingers and see if it makes any difference while you're looking at the controller screen.
Feb 25, 2020 09:57 AM
TLDude876
Dec 28, 2016 03:18 PM
Onyxthecat
Oct 18, 2016 02:05 PM
KillerG
Sep 4, 2015 02:02 PM
Aug 30, 2015 02:39 PM
