Im done trying!
Old Dec 27, 2007 | 03:23 PM
stangg172004's Avatar
_____ like a rabbit
Im done trying!
I cant get my PS3 to connect! I enter everything in and when it trys to get the IP it times out. Any ideas? If it matters im using a netgear router (MR814v3).
These are the steps im taking:
Internet Connection Settings
Yes
Wireless
Scan
X Enter
Right
WEP
Type in WEP
Address Settings Easy
IP Address Settings Automatic
DHCP Do not Set
DNS Automatic
MTU Automatic
Proxy Do Not Use
UPnP Enable
Save Settings
Test Connection
Fail at obtaining IP Address
Old Dec 27, 2007 | 03:34 PM
STL+3.0CL's Avatar
Matt
Just hard code it. Try 192.168.1.2 or 1.102.
How many other devices are using the router?
Old Dec 27, 2007 | 03:39 PM
_____ like a rabbit
PC through Ethernet and two other Laptops but rarely used at the same time and right now neither of them are connected.
Hard code it? use ethernet?
Old Dec 27, 2007 | 03:42 PM
STL+3.0CL's Avatar
Matt
no hard code the IP just use a higher range than devices. So if its a 192.168.1.100 network give it a 192.168.1.105 address with a gateway of 192.168.1.100. That way whenever the laptops or pc's connect it will usually issue a 1.101 or 1.102 or 1.103 but you should be good with 1.105
Old Dec 27, 2007 | 03:45 PM
_____ like a rabbit
so by original IP and the new gateway should be the same and the new IP should be 5 more?
Old Dec 27, 2007 | 03:50 PM
_____ like a rabbit
if i enter the values manually where do i find my Default router values and primary/secondary DNS values?
Old Dec 27, 2007 | 03:52 PM
STL+3.0CL's Avatar
Matt
well first you need to find out what address range the netgear uses (i used 192.168.1.100 as an example) It could be 192.168.0.1 or 1.1. Once you know the range then you can add 5 to the gateways address.
** This is assuming that everything is stock except the password. If the router has MAC exclusions or any other type of custom setup then this wont work.
Old Dec 27, 2007 | 03:53 PM
STL+3.0CL's Avatar
Matt
You can use a public DNS address. For my 360 I just use 4.2.2.2 But your ISP might have a list of recommended DNS address'
Old Dec 27, 2007 | 03:56 PM
_____ like a rabbit
ok i got it to obtain IP but now im getting a DNS error. I used these numbers for the DNS values
DNS Server 68.87.72.130
68.87.77.130
Old Dec 27, 2007 | 04:16 PM
STL+3.0CL's Avatar
Matt
well, you could try using obtain auto DNS. Or try using 4.2.2.2
Old Dec 27, 2007 | 04:35 PM
_____ like a rabbit
tried the 4.2.2.2 values and still the same.
Old Dec 27, 2007 | 04:41 PM
STL+3.0CL's Avatar
Matt
Well, Im outta ideas. Anyone else wanna jump in and give their
Old Dec 27, 2007 | 04:46 PM
HondaAcura83's Avatar
2008 Acura TSX
Old Dec 27, 2007 | 05:49 PM
STL+3.0CL's Avatar
Matt
Originally Posted by HondaAcura83
Old Dec 27, 2007 | 07:20 PM
rex.'s Avatar
Is waiting in
How old is your router? I was having the same problem with my old linksys and then I swapped it out with a newer one. That worked but then I got an all in one combo DSL modem/router. Works like a charm!
