How to cool a Xfire Setup
Old Aug 30, 2007 | 12:44 AM
bz268's Avatar
Because Of You
setup:
AMD X2 6000+
WD 10k Raptor 150Gig
2x ATI 1950 Crossfire
This sh** is running like a microwave oven. I crank up my A/C but this thing is toooo hot.
What can I do?
Old Aug 30, 2007 | 01:21 AM
Stapler's Avatar
Is it overheating, is there anything obstructing the airflow inside the case?
Old Aug 30, 2007 | 01:53 AM
Costco's Avatar
Maybe open it up and clean up all the dust?
Old Aug 30, 2007 | 09:01 AM
Reach's Avatar
Better heatsinks, thermal compound, stronger fans, cable management, thermal management... its hard to say with just a parts list.
Old Aug 30, 2007 | 11:33 AM
demons rage's Avatar
at the very least change the heatsinks on the video cards. it helps a lot
or just go with water cooling. problem solved
Old Aug 30, 2007 | 11:58 AM
bz268's Avatar
Because Of You
I think I need to replace the 120mm fan in the back. It spins 1000rpm only. I think I may try one with 2000+ rpm fan in the back.
Some cases put the power supply at the bottom. Does it matter if the power supply is on the top or at the bottom?
If I put the power supply at the bottom, do I have to flip the P/S upside down so the fan points up?
Old Aug 30, 2007 | 03:12 PM
felixthekat's Avatar
Meow.
Wouldn't putting a power supply on the bottom be a bad thing? I mean, hot air rises, so you'll just be increasing the heat going into the case, making things worse.
Old Aug 30, 2007 | 03:50 PM
bz268's Avatar
Because Of You
All the servers in my office have their P/S put at the bottom... and some of the P/S have 3 fans inside them that can be pulled out while the things are on.
Old Aug 30, 2007 | 04:42 PM
bz268's Avatar
Because Of You
Hmmm... I am looking at this case. Should I just replace my case with this one?
http://www.hardwarezone.com/articles...2&id=2336&pg=3
Jul 16, 2017 07:33 AM
hashbrown
Sep 29, 2015 12:13 PM
dirleton
Sep 29, 2015 08:26 AM
dirleton
Sep 25, 2015 12:25 AM
